Old 28th January 2012, 01:03 PM   #1
CrashHouse's Avatar
Default Altering cabinet dimensions.
While building my T4 amp and modifying it with Jantzen Superior Z caps, I'm rebuilding my vintage Klipsch KG 4.2's. I ordered the Titanium domes at Bob Crites and the crossover caps too. The internal speaker wires are upgraded too in the whole prices. But I have a question cause I'd like to paint the cabinets piano white. Is it possible and easier to build new sleeker cabinets, cause they appeared to be pretty straightforward. No labyrinth or whatsoever. If I keep the volume exact the same will it alter the sound?
Old 28th January 2012, 03:43 PM   #2
Speakerholic
Cal Weldon's Avatar
Yes it will sound different but it will sound better because you made them with your own hands.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 28th January 2012, 04:21 PM   #3
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
A narrower baffle width will raise the F3 point of baffle step loss. Whether or not you will be able to hear the difference is debatable. Once you make the change, no side-by-side can be performed, and the mind/ears aren't very good at picking out small differences like this unless there is a reference to work with at the time.
Baffle width should not appreciably effect the horn loaded part of the system since the directivity more or less eliminates baffle diffraction.
Old 28th January 2012, 06:00 PM   #4
Speakerholic
Cal Weldon's Avatar
Unless he pulls and installs the drivers in only one cabinet to start.
Help! Need dimensions of Eros cabinet jmillerdoc Multi-Way 1 14th December 2010 04:33 PM
4x10 Bass Cabinet Dimensions/Drivers Hobojangles Construction Tips 2 20th October 2010 08:51 PM
altering T/S parameters? AndrewT Multi-Way 24 27th September 2007 11:21 PM
Altering the Cabinet Design daverave Multi-Way 4 28th March 2007 04:04 PM
Altering Crossover for retrofit Autochthon Multi-Way 10 1st February 2007 08:55 AM
Page generated in 0.08698 seconds (77.00% PHP - 23.00% MySQL) with 10 queries
