Hi I m really new to ribbons. Bought a fountek neo CD 2.0 to pair with a seas M15Ch002. However the measurements I get off the fountek look nothing like in the product literature. there is a drop of 10 db between 3k and 10 k.. I am testing the fountek with a 10uF cap in line with a T amplifier. Am I doing something wrong here? Any help would really be appreciated.
#2 |
switched to a 30uf cap.... still the same curve. anyone got any ideas ?
#3 |
No, it works with 10uF...
#4 |
You say a "T amplifier"? Does that mean a Class D that interacts with load impedance? AFAIK the CD2 has a rising impedance at HF from 7 ohms.
I'd try padding the NeoCD2.0 ribbon tweeter with 4 ohms in series, 8 ohms shunt and remeasuring. But keep the level low! Usually people use 3rd order crossovers with this fragile rose. It hates DC or anything close to it. DIY Loudspeaker Projects Troels Gravesen As you say, normal behaviour is a slight increasing brightness at higher frequencies with Founteks. I expect it is quite sensitive to the source impedance driving it, especially as it has a transformer built in. |
| Fountek FR88-EX | inrank | Full Range | 149 | 29th April 2012 05:25 PM |
| New fountek tweeters | Cyan | Planars & Exotics | 4 | 26th October 2011 05:24 PM |
| WTB: Fountek Neo 3.0 CD ribbon tweeters -pair | smallangryboy | Swap Meet | 3 | 2nd October 2011 06:37 PM |
| Fountek FR135EX | type | Full Range | 0 | 27th May 2010 10:38 PM |
| Fountek JP-3.0 | masummo | Multi-Way | 1 | 15th January 2004 06:02 AM |
| Page generated in 0.07684 seconds (73.68% PHP - 26.32% MySQL) with 10 queries |
