Hi , i want to make a 3 way speaker , what do you think of this choice of Drivers ? crossover will be a minidsp 2x8
Scan-Speak 10 inch woofer 26W/4867T00 26W/4867T00 - Scan-Speak 10 inch woofer low loss linear suspension SD-1 motor system aluminium cone - Europe Audio Visaton TI100 http://www.europe-audio.com/Product.asp?Product_ID=815 AMT1908C http://www.rumoh.nl/en/hs-devices/88...0mm-black.html Last edited by FilipeRocha; 27th January 2012 at 07:26 PM. |
#2 |
Wow !! About 2000 € for the speakers + active crossover !
<I spent 100 € ;two coils and 4 caps , I already have> I think it is bad that the woofer is 4Ω : amplifiers are likely to distort DOUBLE when the load decreases . Indeed , the choice of the right speakers is just one part of the many ...it's like following a 30 parts schedule . You won't catch all the technology of those speakers if the rest of the chain isn't at the same level . For example ,that really explendid tweeter can't be played with cd quality 44 KHz/16 Bit to make sure that it has some supersonic abilities . Are the MiniDsp capable of playing 96 or 192 KHz / 24 Bit quality 'files' ? |
#3 |
I've been interested in this combination of drivers. Could be great.
http://www.scan-speak.dk/datasheet/pdf/26w-8534g00.pdf http://www.morelhifi.com/products/pd...et%20MDM55.pdf http://www.morelhifi.com/products/pd...t%20CAT408.pdf
Single-Ended Tube Amp Kit |
| WTB: High quality speakers in NYC | texas11 | Swap Meet | 0 | 30th June 2010 08:59 PM |
| High quality, high voltage (~250V) reservoir caps for PSU | thadman | Power Supplies | 5 | 10th May 2010 09:18 PM |
| Haes high quality German speakers | umut1001 | Multi-Way | 0 | 5th January 2009 09:46 PM |
| High Quality Speakers | SwiftRC | Multi-Way | 1 | 3rd November 2005 04:41 AM |
| High Power High Quality Digital Amp | aspycaudio | Digital Source | 0 | 6th December 2003 09:49 AM |
| Page generated in 0.07739 seconds (72.99% PHP - 27.01% MySQL) with 10 queries |
