Like many others I'm looking at building something along the line of the Orions but greatly reduced in cost. I had thought of the Plutos but the wife didn't like the look .Anyway what I'm thinking of doing is-
Please give any comments/criticisms/suggestions etc. I'm mostly concerned about tweeter choice. Thanks |
#2 |
why not just take the back off the B&G and use it dipole?
#3 |
I was considering it until i read
Comparison Bohlender & Graebener Neo3W and Neo3PDR in dipole mode and Zaph|Audio At $55 each having 4x is OK though. |
#4 | |
#5 |
In fact, if you would apply the same acoustic target curve (say, an acoustic LR4 high pass at 1,5 kHz), the version with two closed back tweeters would have higher distortion due to the non-linear compliance behind the diaphragms.
If the same, Orion-like wide baffle would be applied, the polar patterns of the two configs would be virtually identical. The polar pattern with a wide baffle would also be quite different from Keyser's data. |
#6 |
For the tweeters I see no reason to use the same model front and back, possibly go for a cheaper higher value model for the rear, as its relatively attenuated to the front. rgds, sreten. (AFAIUI the neo 3 without the back cup has an overdamped response not suitable for a passive two-way normal x/o point. Might work very well in an open baffle with some active EQ. I understand you can also build some form of mini waveguide for it in the baffle, to boost low end.)
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#7 | |
#8 | |
I don't believe in audio believings. |
#9 |
Thanks for sharing the measurement. The peak at 700 Hz is the driver's free air resonance frequency if I'm not mistaken (no cavities involved indeed).
#10 |
One challenge you will face with the Neo3 in dipole mode will be the assymetry in front/back radiation from the mid-woofers. As you only have one crossover which you will optimize for the front radiation and the midwoofers back radiation starts to differ significantly from the front radiation from a certain frequency (typically in the crossover area 2-3 kHz), you'll typically end up with a hole in the frequency response towards the back.
Some options you have for mitigating the issue: 1. low crossover frequency - I have seen this being used in the Adire MTM design, but requires a steep filter for Neo (they used 6th order @1.8kHz). Also, the original Orions use a very low crossover point (1400 Hz IIRC) 2. a true dipole midrange like the Neo10 3. a helper driver(tweeter) on the back 4. using back-to-back drivers - with this, you have the freedom to shape the rear tweeter response to match the rear response of the midwoofers Only 1 and 2 will give you a "true" dipole in the strict sense, however I am not really sure if that audibly matters higher than 2 kHz or so, given you get a good power response. I opted for 3. Liviu
| Blu Ray BD Disc "In Concert" resp "live at" - Overview wanted | tiefbassuebertr | Music | 2 | 5th January 2012 02:54 PM |
| The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter | River757 | Multi-Way | 14 | 7th September 2011 06:41 PM |
| Blind listening test with Orions, cheap pro sound and even cheaper DIY | Godzilla | Full Range | 16 | 19th November 2010 07:10 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Page generated in 0.11331 seconds (80.41% PHP - 19.59% MySQL) with 10 queries |
