vented box & loudspeaker stuffing
Old 20th September 2003, 10:18 PM   #1
sstoiana is offline sstoiana  Romania
Default vented box & loudspeaker stuffing
*newbie*
I've built a few boxes, mostly by ear, with some degree of succes. However, I've had a few problems with vented designs (cone excursion exceeding xmax
I have just discovered WinISD, and was experimenting with some vented box designs. Thing is, I don't really understand how Qa works.
The help file states :
"Qa, absorption losses. These are produced by losses in enclosure. Any stuffing will increase the absorption loss. With no stuffing inside the box, 100 is typical. Heavily stuffed enclosure has this about 3-5. "
What does "heavily stuffed enclosure" mean ? That there is only stuffing inside the box ? Then what would Qa=50 mean ? 50% of the box is filled with stuffing material ?
Another question:
What material is best for stuffing ? I've seen (and heard of) at least a dozen different materials used, from virgin wool to polyurethane foam, fluffed cotton fibers to chopped up rags. What's best ? And how would you fix it inside the box ?
Any help is apreciated!
Old 21st September 2003, 02:54 PM   #2
SisterOfMercy is offline SisterOfMercy  Europe
SisterOfMercy's Avatar
I use pritex, which I think is some sort of polyurethane foam.. I fix it to the cabinet with bitumen plates that have double sided adhesive..
vented box & loudspeaker stuffingHide this!Advertise here!
Fiberglass stuffing and vented magnets LineArrayNut Multi-Way 5 13th November 2008 03:53 PM
David: Small vented loudspeaker with bass boost Dominique Multi-Way 4 21st May 2008 03:17 AM
Aerogel as a loudspeaker stuffing material Oborous Multi-Way 13 21st November 2006 06:58 PM
Loudspeaker Stuffing Theory ? brianon Multi-Way 7 18th November 2006 05:48 PM
Stuffing in vented boxes jethari Multi-Way 14 23rd October 2002 01:33 AM
Copyright ©1999-2017 diyAudio
