Old 26th January 2012, 04:58 PM   #1
Default Cheap Tweeter Horn Line Array
As an extension of the "Stupid Cheap Line Array" thread, I'm curious what horn fans think about this. I've been considering horn loading an array of 64 Apex Jr. tweeters and horn loading them (more like waveguide). I'm not interested in increased sensitivity as much as I'm interested in smoothing response. I am, however, hoping that it would be possible to gain efficiency on the 10k+ region in order to reduce the required in-room reflection that is the only hope to balance out the combing effect on individual drivers. Any recommendation on horn shape/design?
FYI, I'm going to array these next to a line of 3" Aurasounds (the cheap 16ohm guys). The 5.25" Aura woofer will be in a separate cabinet for placement testing purposes.
Thanks,
Greg
Old 26th January 2012, 05:23 PM   #2
I experimented in 2005 with 90 degree waveguides on small tweeters.
The waveguide does little to increase efficiency on the 10k+ region because the piston diameter is already causing the tweeters to be more narrow than the waveguide.
The test results are below.
The reason nearly all pro line arrays use compression driver horns with very narrow vertical dispersion rather than tweeter lines is obvious.
If you don't want to go that route, ribbon tweeters would be a better choice for a line array than dome tweeters, as their narrow HF vertical response causes far less comb filtering.
Stupid Cheap Line Array gmcalabria Multi-Way 252 18th May 2012 03:17 PM
advice needed for cheap line array tweeter zobsky Multi-Way 23 15th September 2009 04:24 PM
Tweeter line array Klimon Planars & Exotics 11 5th October 2006 09:01 PM
Can you say the new cheap line array boner is here? Feandil Multi-Way 0 21st April 2005 10:28 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
Page generated in 0.06160 seconds (70.00% PHP - 30.00% MySQL) with 11 queries
