Hi everybody,
I need some advice. What happend if I use a driver with EBP of (fs=110. Qes 1.02) 107 in a closed box, instead ported box? What happend to the sound of the speaker. Thanks, Andres |
#2 |
Please name the driver model for complete reference.
#3 |
Thanks Inductor,
The diver is the next. Aurasound NS3-193-4A1 3" Extended Range, Black Cone, * 4 ohm *: Madisound Speaker Store |
#4 | |
This driver works nice in OB (simulations). Last edited by Inductor; 26th January 2012 at 08:03 AM. |
#5 |
Thanks Inductor, you are very kind.
#6 |
Something looks a little off about that sim to me... I get this:
#7 | |
It all depends on the alignment desired. dumptruck, that's not something I haven't said (text) on #4 (note: all softwares are a representation and some/all not that accurate, to have in mind in posterior comparisons) Last edited by Inductor; 27th January 2012 at 06:45 PM. |
#8 |
Hi dumprtruk, thanks for your help. Can you go further in your ideas? What you suggest to do?
#9 |
Inductor, yes it agrees with your text - I thought your graphic was showing a sealed 2.7 liters, now I realize it is ported at 54Hz, and correct
Andres, it depends on how you are wanting to use this driver. You can see the bass response difference above. Unless you are using a high-pass filter on them, a single ported driver will begin to distort by about 2W, sealed 4W (about 85 and 88dB @ 1m, respectively). Last edited by dumptruck; 27th January 2012 at 08:30 PM. |
| Midrange enclosure volume and EBP question | marscoast | Multi-Way | 9 | 16th October 2007 04:12 PM |
| EBP and QTS | horus | Multi-Way | 27 | 2nd January 2007 12:29 AM |
| Does EBP matter for small drivers? | coolkhoa | Multi-Way | 1 | 2nd August 2004 04:26 PM |
| Calculating EBP for sealed enclosure drivers... | sberube | Multi-Way | 2 | 4th June 2004 08:14 AM |
| Efficiency Bandwidth Product[EBP] of cone speaker drivers | Bull | Multi-Way | 4 | 30th July 2003 05:23 PM |
| Page generated in 0.09662 seconds (78.42% PHP - 21.58% MySQL) with 11 queries |
