Old 23rd January 2012, 05:59 PM   #1
Default 3a Andante Ultra Lineaire
Dear All,
I just purchased my new 3a Andante Ultra Lineaire speakers. It seems that seller didn't say all to me, so now I have problems with them. On one unit I have hum, so I need to repair it.
Do you have perhaps any experience what to do or what to change after all years, or service manual. Any help is appreciate and welcome.
Thanks, regards,
Boris
Old 23rd January 2012, 11:28 PM   #2
Hello, unfortunately, i can't help you with your problem but, someone here
probably will.
The integrated feedback amplifier probably defective.
Don't give-up on those as they were/ are remarkable speaker system!.
How are the woofer suspensions? rotten? still white originals?.
I always wanted a pair of those!...
Good luck!.
Old 23rd January 2012, 11:32 PM   #3
Boris, maybe someone here:Enceintes 3a : Audio - Général - Cinetson - Hifi et Homecinema
can help you...
It'a a french site but who knows?...
Old 24th January 2012, 04:21 AM   #4
Thanks for answer..
Surrounds are still original white and are ok, not rotten...
I'll let you know about solution...
Boris
Old 29th January 2012, 01:52 PM   #5
Dear all,
Now i have something...
I replaced all electrolytic caps in this device. Now I'm testing only one, the second is not finished yet.
When I put 230 V, The speker made a large excursion - big "thump". Nothing else, and relais click.
Now, I have no speaker signal, only is connected to mains.
Is there anybody who has experience with "thump" thing. As I said all electr. caps are changed, MKT or MKP are the same and it seems that all semiconductors are OK. Fuses are OK too.
Any help?
Boris
Old 25th February 2012, 01:56 PM   #6
Hi mate !
I have had the same problem , I've got a 3a Andante "Prelude" bi amplification system , when my woofer was blow I tried to replace it with another one. When I plug in woofer make the terrible noise like u are saying then I've ordered a woofer ,mid and a tweeter replaced all of them now he is working perfect.
Here is a view of him
3a -Andante "Prelude" , 3Way Active Speaker , Power 270 Watt 8 Ohms. - installingway's Gallery - Canuck Audio Mart
I had tried to replace voice coil of woofer but sounds so bad,so if your back amp is okay change the speakers it's only way.
P.S how can I see your speaker ?
Old 11th April 2012, 09:22 PM   #7
ief is offline ief  Netherlands
ief's Avatar
Don't know if you're still working on these but I have the schematic for the master control witch is very likewise. Mine have the thumb 2 and I could be wrong but suspect it to be 'normal'. Usualy you only plug them in once and be done with the thumping Just try and give them some signal and see (hear) what they do?
Old 12th April 2012, 04:19 PM   #8
seanny is offline seanny  United States
The feedback looks complex. Is it designed for a particular woofer or any woofer?
Old 12th April 2012, 05:20 PM   #9
ief's Avatar
I suspect the are for a particular woofer (they are in house designed/ made). I never got a conclusive answer to how and what they exactly did. No piezo element and I thought someone mensioned an extra winding on the coil but I'm realy not sure.
They sound pretty good btw, mine are not in to good of a state and still I like them a lot.
Don't use them anymore though since the don't like working without earthing and my unearthed pc or so I believe anyway. (something went wrong one time and burnt out a resistor bad...)
Old 29th April 2012, 05:54 PM   #10
Hi there again ,
Okay I think you should change that burned resistor also you should check the diodes and capacitors close to him if they are in working conditions, and I don't know why you have connected that wire on transistor ?! . When you check these make a short connection with black wire and red then connect the woofer(whatever woofer) on green and blue wire then put on power connect the signal and it will work , here is a view of second amp that I have repaired successfulyClick the image to open in full size.
For sale: Ultra Analog DAC, Ultra Analog AES20, HDCD filter mihow2007 Swap Meet 1 27th February 2011 06:33 PM
+/- 28V 3A supply andRookie Power Supplies 29 7th May 2010 10:16 PM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
Seeking ultra, ultra mini 1uF elec cap Triophile Parts 11 6th April 2005 11:17 PM
A new ESP 3A amplifier! Duo Solid State 7 14th April 2003 02:59 PM
Page generated in 0.10723 seconds (78.94% PHP - 21.06% MySQL) with 11 queries
