Old 23rd January 2012, 04:34 PM   #1
Unhappy Advice B4 Crossover
I have a pair of JBL 4430 monitors and have been trying to bi-amp them with a modest BBE crossover. Not happy with results. I have a Bel Canto Set 40 for the top. Any low end amp and crossover suggestions? FW B4?
Old 23rd January 2012, 04:50 PM   #2
Speakerholic
Cal Weldon's Avatar
Hi Paul,
I moved this over the the loudspeaker section.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 25th January 2012, 09:23 PM   #3
Speakerholic
Cal Weldon's Avatar
Just bumping this as I am interested in others' opinions as well. Which model XO do you have and what seems to be the problem(s)?
Old 25th January 2012, 11:58 PM   #4
VaNarn is offline VaNarn  Australia
The JBl constant directivity requires equalisation to match the 93dB sensitivity of the 15" bass driver.This is all explained on the Lansing Heritage site.Basically the level of the horn is reduced by 15-16dB at 1kHz and an approximate 6dB per octave corrective slope applied above 3kHz.
Old 26th January 2012, 09:59 AM   #5
AllenB is offline AllenB  Australia
Yes, this isn't straightforward. It will be difficult to improve on. The crossover will need to match the drivers in power and directivity, as well as equalising the horn, plus any other 'issues' that might be present.
You might be able to use an active crossover to mimic the transfer function of the crossover, if you can measure that. Otherwise if you're unable to take and convert polar plots of the drivers I would think it best to stick with the stock crossovers, unless there is a proven alternative.
Old 27th January 2012, 03:37 PM   #6
I have a JBL2342/JBL2425 with an 8" Peerless.
I had high expectations but ....FAILED
Back to the drawing board
AmpsLab.com
Pass Labs B4 crossover questions nicksgem10s Pass Labs 19 27th January 2012 10:44 PM
B4 and using different pair of monoblock edwyun Pass Labs 11 2nd April 2011 06:42 PM
Is B4 still on the horizon? Michael Rothacher Pass Labs 12 14th March 2011 11:46 PM
Any news on B4? Chul Pass Labs 5 9th December 2009 03:50 PM
anyone build this amp B4? space2000 Solid State 1 17th May 2008 09:06 AM
Page generated in 0.09276 seconds (72.62% PHP - 27.38% MySQL) with 11 queries
