Old 23rd January 2012, 01:22 AM   #1
3GGG is offline 3GGG  Australia
Default Who has built petal horns?
Who here as successfully built petal shaped horns? I am still researching wether to build mdf rings and turn them, buy from horns.pl or even build petal horns, with 11 or 13 sides.
Looking at a 200hz tractrix with a 1.4 inch throat and a 120 hz tractrix with a 100mm opening.
I am on a mac so no hornresp
I got inspired for the petal design when i saw the lute my father is building and though some bendy ply and a few templates could be a fairly easy horn build.
Old 23rd January 2012, 04:39 AM   #2
Brett's Avatar
I made some about a decade ago with a free program I found online to plot out the segment shapes. I then used some board a friend got from an art shoppe in watermelonville but I forget what it's called. White and smooth, couple of mm thick and bent very nicely.
I'd be wary of a 200Hz trax, as I had a 220Hz unit turned out of mdf and it beamed like a mongrel, to the point I found it unusable. If you're doing a bigger horn for the MB something similar in size to the Edgar 350hz flare, used above 500hz would work better. Check out Volvotreter's site.
Old 9th February 2012, 04:36 AM   #3
MartinV56's Avatar
HORNS - HiFi Chile - Página 18
Post No.538
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Who has built RCA Fan's half-horns and BLH? freddi Full Range 0 14th January 2007 04:46 AM
TAD and horns, where to get horns? Daveis Multi-Way 15 13th September 2006 01:07 PM
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 10 27th December 2005 09:10 AM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
Page generated in 0.05725 seconds (80.69% PHP - 19.31% MySQL) with 10 queries
