Old 22nd January 2012, 04:01 AM   #1
Default Beyma 12G40 for a 3 way?
I was wondering if the Beyma 12G40 low frequency woofer would be a good canidate for a 3 way home stereo tower cabinet? I have 2.65 cubic feet of volume with 2/ 3.5" ports. My amp is a Adcom GFA 555ii. My crossover has been designed for a 4 ohm woofer. Thanks
Old 22nd January 2012, 05:41 AM   #2
jerome69's Avatar
The 12G40 is fine for the box but not the crossover. Redesign the crossover or choose an other woofer (B&C Speakers 12PH32 4ohms ?)
Old 22nd January 2012, 12:30 PM   #3
They make a 4 ohm version of the 12G40.
Old 22nd January 2012, 12:33 PM   #4
You'll have to design a new crossover in any case. A standard or previous one will simply not work.
Old 23rd January 2012, 12:52 AM   #5
Why would a crossover designed for a 4 ohm woofer need to be re designed? How would one know what the current design is? Does every woofer that is 4 ohms require a redesigned crossover? I'm sooooooo confused
Old 23rd January 2012, 01:01 AM   #6
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
As I have learned here recently, unless the x-over is somewhat fine tuned for specific driver response and impedance characteristics of the drivers intended to be used, the results are not likely to be all that flat. It's *possible* for the speakers to turn out working reasonably well without a simulated design, it's however more probable that they turn out pretty far from flat.
Old 23rd January 2012, 01:56 AM   #7
Thanks for the explanation. Perhaps I should post the crossover values someone could give me a better idea?
Old 23rd January 2012, 04:02 AM   #8
Default My current crossover set up
My crossover is as follows:
4 Ohm 12" Woofer Cerwin Vega
Resistor 5.0 ohms 10 watts
16 AWG Air core coil 2.2mH <0.5 ohms
Cap. 100wv 80/0uF <10%
Cap. 100wv 60/0uF <10%
4 Ohm 5.25" Midrange Scanspeak
16 AWG Air core coil 1.6 mH <0.5 ohms
16 AWG Air core coil 0.8 mH <0.5 ohms
Cap 100 mv 20/0uF <6%
Cap 100 mv 18/0uF <10%
6 ohm Tweeter 1" soft dome Scanspeak
16 AWG Air core coil 0.4 mH <0.5 ohms
Cap 100 mv 3.0/0uF <6%
Cap 100 mv 8.0/0uF < 6%
Crossover Frequincies 500Hz - 3kHz
Old 23rd January 2012, 04:41 AM   #9
jerome69's Avatar
Here not need to redesign anything
Find a woofer with closed specifications
Old 23rd January 2012, 06:29 AM   #10
If you can get specific model numbers on the other drivers, then maybe we can pull some manufacture response and impedance charts and run a sim with the woofer you want to run and see if it will work.
Eric
Tqwt with Beyma BEYMA 12XA30/Nd simulation sladdbarn Multi-Way 8 24th February 2012 02:25 PM
Beyma 8BX audiothings Multi-Way 1 23rd February 2011 02:11 PM
Help: Beyma 12G40 vented options? oLjud Multi-Way 23 24th August 2010 05:12 PM
Help with Beyma design Pooley Multi-Way 4 29th June 2009 10:56 PM
Has anyone experience with Beyma??? DarkOne Multi-Way 1 25th February 2002 12:29 PM
Page generated in 0.08599 seconds (87.36% PHP - 12.64% MySQL) with 10 queries
