A Test.  How much Voltage (power) do your speakers need?
View Poll Results: I measured the test tone at:
2 volts or less 234 38.61%
Between 2-5 volts 193 31.85%
Between 5-10 volts 84 13.86%
Between 10-20 volts 40 6.60%
Over 20 volts. 55 9.08%
Voters: 606. You may not vote on this poll
Old 29th January 2013, 03:05 PM   #801
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Going on original instructions - its been a while since I looked over here.
With the -18db sounding like Niagra I hit 152.3 millivolts. So 0.4v rms
I need to go back to school
If I'm not making noise, I'm making something to make noise
Old 30th January 2013, 05:31 AM   #802
Pano is online now Pano  United States
Pano's Avatar
OK, sounding like Niagra? You were using the pink noise? Please try the -12dB sine wave files. Pick the frequency that works best for your system.
Old 5th February 2013, 12:11 PM   #803
regal is offline regal  United States
Just to give folks an idea of how hard it is to power new ortho headphones, I measured 1.3Vrms with the -12db tracks, thats higher than the majority of speakers meaurements in the poll.
Old 5th February 2013, 12:25 PM   #804
jakubg is offline jakubg  Slovakia
Don't forget that headphones usually have higher impedances.
Therefore 1.2V into 60 ohms (audeze LCD2) is 0.024 watts.
Its the same as 0.44V into 8 ohms.
But still, it's a lot of power for headphones (remember you are listening centimeters away, not meters like with speakers).
Old 7th February 2013, 03:36 PM   #805
pierre77 is offline pierre77
Dear Pano
thanks for the post, I'll take the test asap. I am struggling with the "gain staging" problem.... I never thought about it before I strated to play with active xover!. It's damn important, I realize!
I have the following basic question which has somehow to do with gain-staging and this voltage test all together.
Suppose my speaker have:
Z_min = min impedance across the spectrum,
S = speaker sensitivity in dB/2.83V/1m, anechoic
I want to produce X dB at the Y meters under anechoic conditions. How do I compute:
1. Vmax = the voltage required by the amp
2. Imax = the current need
I hope somebody can give me forumlae to compute those quantities.
Best Regards
Pierre
Ps: I may try to answer that answer that Imax=Vmax/Zmin,
Old 7th February 2013, 04:14 PM   #806
weltersys is offline weltersys  United States
weltersys's Avatar
Pierre,
Voltage x Voltage divided by impedance=watts.
SPL drops at 6 dB per doubling of distance outdoors or in an an anechoic chamber.
A 90 dB one watt one meter speaker driven with 10 watts will be 100 dB, at 2 meters 94 dB, at 4 meters, 88 dB etc.
Assuming a nominal 8 ohm speaker, the 10 watts would require 8.944 volts.
Old 7th February 2013, 11:20 PM   #807
Pano's Avatar
And as mentioned, that is outdoors or with no reflections. It usually does not drop what fast in a room. If you are in a room, I suggest pink noise playing on both speakers and an SPL meter.
For example: With both speakers playing I get ~84dB at my listening position with 1V on the speaker terminals. I'm not sure what that translates into for each speaker a 1W/1M, but I know the voltage I need to hit 84dB where I sit.
Take the Speaker Voltage Test!
Old 11th February 2013, 09:35 PM   #808
Lavcat is offline Lavcat  United States
Lavcat's Avatar
Speaking of headphones, for my nominal 25 ohm Denon D7000's I measured 0.336v using Pano's -12dB test tone.
Old 12th April 2013, 05:55 PM   #809
Vaughan is offline Vaughan
This method won't determine sudden changes in signal amplitude? If I'm watching a movie like Master and Commander, Chapter 4, before the cannons start, there is almost silence but when the action hits it hits very hard.
Now how would one determine how much voltage was used during those sequences? Because people say you need "x" watts to watch a movie and that more power will help in a given scene.
It would be interesting to put that to the test to test dynamic events from movies at a loud volume and see how much power is being used.
Old 12th April 2013, 05:59 PM   #810
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
it would be just the same thing done in this thread.
are you sure you read and understood the procedure?
nevertheless, everyone is free to believe that there are occult/unmeasurable phenomena at play.
we all love a good ol' stereotype until it's against us
A Test.  How much Voltage (power) do your speakers need?Hide this!Advertise here!
LM3875 power up test.. and it crackles w/o speakers attached? Keyoke Chip Amps 9 2nd March 2012 02:39 AM
how to test chokes for current and voltage speakerfritz Tubes / Valves 10 20th October 2010 12:32 PM
Aleph 30 problem - half of power supply voltage on speakers output yoke Pass Labs 18 15th March 2009 06:18 PM
How to test speakers? zaydenam Multi-Way 2 27th August 2008 02:02 PM
Test speakers? Ryssen Multi-Way 3 2nd March 2004 11:54 PM
Copyright ©1999-2017 diyAudio
