A Test.  How much Voltage (power) do your speakers need?
View Poll Results: I measured the test tone at:
2 volts or less 229 38.17%
Between 2-5 volts 193 32.17%
Between 5-10 volts 84 14.00%
Between 10-20 volts 40 6.67%
Over 20 volts. 54 9.00%
Voters: 600. You may not vote on this poll
Old 20th January 2012, 03:48 PM   #21
Pano is online now Pano  United States
Pano's Avatar
Originally Posted by Flaesh View Post
p.s.: woofers are equalised about +13dB @ 30Hz. so there is more voltage..
Good point. The test is simple an does not take into account EQ. If you have a boost somewhere then your voltages at that frequency will be higher. Your 30Hz boost will need about 4.5X more voltage than you measured.
Conversely, if you had a cut at 120Hz or 220Hz, your readings would be off.
Bill, thanks for your results and the good info. I'm surprised about the interaction with the meter, what type is it?
Originally Posted by wrankin View Post
I am also not sure if the "sample music" I listened to was normalized to the same level as the tones.
It probably isn't, but it does not matter. Here's why:
Once you have set your level, it's set. Because digital playback has an absolute maximum level (a ceiling) we know the voltage can never go higher than that.
The test signal is 12dB lower than that ceiling. So the max voltage possible is 4X what you measure from the test tone. Make sense?
However, if you wanted to know the average level, then matching the test tone to the music is important. Looking at a lot of recordings, I see that most loud sections have an average level of -10dB to -12dB. Of course they aren't all like that, but those levels are typical. And that's one of the reasons I chose -12dB for the test signals.
If you have software like Goldwave, you can open the music file and read its average level. Read the whole file, or just a selected part of it. Very handy tool.
Old 20th January 2012, 04:09 PM   #22
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Results
9.42 VAC @ 120 Hz, 8.99 VAC @ 220 Hz.
Carver TFM-15CB driving my DIY MTM, dual 6.5", Four Ohm, Trick Piezo.
Room size 5M by 5.5M.....A rather "live" room, ceramic floor, cemented walls, no particle board nor drywall ..........A decent volume, turned up just shy of onset of distortion harmonics.
__________________________________________________ ______Rick.......
Last edited by Richard Ellis; 20th January 2012 at 04:10 PM. Reason: additional thoughts
Old 20th January 2012, 04:20 PM   #23
forr is offline forr  France
forr's Avatar
This kind of test needs a voltmeter with a voltage-peak-hold function (I own four having it...) connected across the driver or the loudpseaker and some records having modulation peaks reaching the full scale deviation (FSD).
Yesterday, I discovered this program
ocenaudio
It can provide statistics on a record :
Peak amplitude; Minimum, Maximum and Average levels in dB (awfully called "Powers").
From there, you can obtain a lot of informations about the voltages applied to your speakers, if they may ever suffer from thermal compression, if your amplifiers ever clip, etc...
This could help to extend this disccussion which deserves it :
http://www.diyaudio.com/forums/solid...ns-wanted.html
Old 20th January 2012, 04:24 PM   #24
AndrewT is online now AndrewT  Scotland
Forr,
this kind of test does not need a special voltmeter.
The test signal is a constant amplitude steady sinewave chosen to be in the reasonably accurate range of cheap average reading DMMs and scaled to read out in Vac.
regards Andrew T.
Old 20th January 2012, 04:26 PM   #25
Pano's Avatar
Yep. Exactly what Andrew said.
But thanks for the link, I'll check it out.
Old 20th January 2012, 04:38 PM   #26
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I get 1.88V at just under neighbor aggravating levels, which is a little lower than I would like most of the time. Good thing my amp is capable of 200Wrms @ 8ohm.
Speakers are Phase Technology PC80's (88dB/2.83V/1m).
Old 20th January 2012, 05:16 PM   #27
forr's Avatar
Originally Posted by AndrewT View Post
Forr,
Using musical signals, knowing peaks and average voltages applied to the amplifiers and loudspeakers (and drivers in multiways) gives a larger and more detailed picture of the whole than measuring volts of continuous low frequency sinewaves according to the proposed test procedure. I think that the peak hold function can now be found on some low cost multimeters.
Old 20th January 2012, 05:16 PM   #28
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by Pano View Post
You using 120V at -12dB on speakers in your living room, Art?
I did not include a 100V+ scale because most folks here aren't trying to fill a stadium. Home systems are the aim of this test.
But your points are valid and I appreciate the data points, thanks.
I find 110 dB of LF adequate in my living room, and don't have room for a 45 x 22.5 x 26.5 speaker, and my Technics tuner sub output can probably only do 30 volts or so.
The rather efficient (around 101 dB 1 watt 1 meter) Keystone tapped horn sub has been duplicated by PASC, he is considering replacing his present subs in his home stereo with that speaker.
Lots of people get used to 120 dB of bass in car and concert systems and want to reproduce that in the home, without cabin gain it takes a lot of horsepower to do it.
The 120V test was done in my shop in an area around 20 x 16 x 9, and was off scale (over 126 dB) on my dB meter at one meter. I actually don't find 130 dB at 30-40 Hz peaks uncomfortable, though I don't listen above 110 dBC, 90 dBA in my home stereo.
My shop seems to saturate around 120 dB at low frequencies if listening in the middle portion, increasing voltage does not increase level after a point.
Wobbly walls and phase cancellation.
Of more usual home stereo interest, the Acoustic Research AR2 at 10.9 volts was pretty anemic, only about 100 dB at one meter, a pair in my shop (or living room) may have done about 95 dB maximum at normal listening distance.
I think the AR2 was a 4 ohm speaker with a 87 dB rating, 10.9 v is around 30 watts, and that was as much as it could take without exceeding 10% distortion at low frequencies.
They definitely ran out of gas below levels I like with some types of bass heavy music.
Art
Old 20th January 2012, 05:25 PM   #29
weltersys's Avatar
Unfortunately, the integration time on multimeters is far to slow to read musical peaks with any detail or accuracy.
Old 20th January 2012, 06:44 PM   #30
Pano's Avatar
Originally Posted by theAnonymous1 View Post
...just under neighbor aggravating levels, which is a little lower than I would like most of the time
LOL
Thanks for posting.
I agree. It would be nice if you could do this, but I would not trust the meter on music. An Oscilloscope, yes.
However: If you think you need to measure peak values, you have missed a fundamental part of the test. We already know where the peaks are, they are 12dB higher than the test tone. That's 4X the voltage. Where else could they be?
The test tone could be at any other level, as long as you know what that level is, you know where the peaks will be.
A Test.  How much Voltage (power) do your speakers need?Hide this!Advertise here!
LM3875 power up test.. and it crackles w/o speakers attached? Keyoke Chip Amps 9 2nd March 2012 01:39 AM
how to test chokes for current and voltage speakerfritz Tubes / Valves 10 20th October 2010 11:32 AM
Aleph 30 problem - half of power supply voltage on speakers output yoke Pass Labs 18 15th March 2009 05:18 PM
How to test speakers? zaydenam Multi-Way 2 27th August 2008 01:02 PM
Test speakers? Ryssen Multi-Way 3 2nd March 2004 10:54 PM
Copyright ©1999-2017 diyAudio
