A Test.  How much Voltage (power) do your speakers need?
View Poll Results: I measured the test tone at:
2 volts or less 231 38.31%
Between 2-5 volts 193 32.01%
Between 5-10 volts 84 13.93%
Between 10-20 volts 40 6.63%
Over 20 volts. 55 9.12%
Voters: 603. You may not vote on this poll
Old 4th February 2012, 03:59 AM   #281
5th element is offline 5th element  United Kingdom
5th element's Avatar
Originally Posted by mr_push_pull View Post
I'm not sure everyone here owns a scope. I don't.
I do and I use it. It's just that I understand what Pano's test is trying to do and I know that unless the amplifier is going to go into current limiting before it hits the voltage limits, that Pano's test is just as good as using the scope.
In fact Pano's test is somewhat better then using the scope and here's why.
Using the scope with music and watching the wave forms is a bottoms up way of doing the test. That is, I can watch the scope trace and look for any clipping but it's heavily dependant on the music being played. That is music starts at silence then goes its merry way reaching certain peaks. What I really need to do, to make sure that I will be clip free at that volume, is play a sine wave sweep but start right at the top, that is 0dB. If the sine wave sweep played at the maximum digital amplitude for that given volume ends up clip free on the scope then I'm home dry.
Pano's test goes about finding this exact same level at 0dB, but does it without the need for a scope.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 4th February 2012, 04:02 AM   #282
a.wayne is offline a.wayne  United States
Sin Bin
What 5th is saying is correct but it does not apply to what Tom and I are speaking of ....
5th your are applying the fix digital signal as supplied by pano after using an variable analog signal to set gain with no reference . The best way to do this correctly is to use the scope , your zero db reference is nothing more than the loudest volume reached it does not represent the max of anything more than the limit acceptable by the user on a specific recording ....
Pano should do a recording to be used by all , along with the test tone , if not we have no reference so the numbers are useless for comparisons or any conclusions...
Old 4th February 2012, 04:05 AM   #283
Sin Bin
Pink noise and a db Meter , measure the voltage .....
Old 4th February 2012, 04:07 AM   #284
Pano is offline Pano  United States
Pano's Avatar
Tom, with all due respect, you simply do not understand this test. I respect your experience and designs, but you are not understanding the test - and I don't know why.
Please read post #277, all you need is contained therein.
The first sentence of post #279 may also help.
BTW, there has been no resistance to looking at a 'scope by those who own them. None. The only thing close to that is that one doesn't need a 'scope for this test. Nothing wrong with using one if you have it.
Old 4th February 2012, 04:13 AM   #285
Sin Bin
Pano the test is done using pink Floyd , will the results be the same switching to the 1812 symphony ....?
Old 4th February 2012, 04:14 AM   #286
Pano's Avatar
Yes, the test results will be the same voltage. However, if you set your levels with Floyd, then your 1812 levels will probably be too low, by ear. The test tone won't care a bit.
So if you want to know how much voltage you need not to clip very dynamic tracks, then set the volume with the 1812 overture.
This says to me that you don't understand the test. Yes, I could supply a recording, but what good would that do? Don't you already own recordings? Can't you pick a few typical or dynamic ones and set your "As Loud as I like it" volume? The SPL is beside the point. The point is, "this is my highest volume setting" no matter what recording.
The object of the test is not to determine what SPL is "Loud Enough" for you and your system, but what voltage your amp puts out once you have reached that level.
Old 4th February 2012, 04:16 AM   #287
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
buying a scope is one of those things that I keep on postponing. I oscillate between an used Tek/HP/etc, a brand X one, a USB scope and a digital Chinese scope until I get bored and give up
I can't see how one can follow the waveform on the scope display to catch clipping
btw I just realized that we're going on about clipping when it wasn't even mentioned by Pano.
we all love a good ol' stereotype until it's against us
Old 4th February 2012, 04:18 AM   #288
Sin Bin
Dynamic clipping is easily viewable with a scope ......
Old 4th February 2012, 04:18 AM   #289
Pano's Avatar
I think I've mentioned clipping a few times. That's the whole idea of the test.
Old 4th February 2012, 04:21 AM   #290
my thoughts exactly, I somehow have the feeling that there's a lot of confusion floating around but can't put my finger on it. maybe it's me who doesn't get it.
A Test.  How much Voltage (power) do your speakers need?Hide this!Advertise here!
LM3875 power up test.. and it crackles w/o speakers attached? Keyoke Chip Amps 9 2nd March 2012 02:39 AM
how to test chokes for current and voltage speakerfritz Tubes / Valves 10 20th October 2010 12:32 PM
Aleph 30 problem - half of power supply voltage on speakers output yoke Pass Labs 18 15th March 2009 06:18 PM
How to test speakers? zaydenam Multi-Way 2 27th August 2008 02:02 PM
Test speakers? Ryssen Multi-Way 3 2nd March 2004 11:54 PM
Copyright ©1999-2017 diyAudio
