A Test.  How much Voltage (power) do your speakers need?
View Poll Results: I measured the test tone at:
2 volts or less 241 38.87%
Between 2-5 volts 197 31.77%
Between 5-10 volts 85 13.71%
Between 10-20 volts 41 6.61%
Over 20 volts. 56 9.03%
Voters: 620. You may not vote on this poll
Old 27th January 2012, 04:57 PM   #111
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by Speedskater View Post
Don't you need to use the same digital source to play the test tone as you used to play the high volume music?
Yes, you do.
Originally Posted by back View Post
your way is wrong.
No, it's not. Check your math and you will see. Your 890 watts is the result of a faulty calculation. You threw amperage in there were you didn't need it. See my previous reply.
Old 27th January 2012, 05:38 PM   #112
back is offline back  Greece
Originally Posted by Pano View Post
Yes, you do.
your calculations say that the peak power is twice the rms power +3db
but this is not the case.
i guess it depends at the music but i can make a 600 watt rms amplifier
distort.
on the contrary my other amplifier 1200watt rms can drive the speakers
to the point the protection kicks in with no audible distortion.
Old 27th January 2012, 05:56 PM   #113
Mooly's Avatar
Well done Brian very concise explanation.
Old 27th January 2012, 06:07 PM   #114
Tom Danley is offline Tom Danley  United States
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
I am not clear how this tells you “how much power” other than under the assumption made.
If one takes the AES style pink noise used for testing, one finds the peak to average ratio is 6dB, that is the peak Voltage is twice what the average Voltage is and so if one wanted to test a loudspeaker at a 100W AES pink noise rating, one needs at least a 400Watt amplifier to deliver that signal unclipped.
This is signal is only surpassed in heating value by the instrument amplification or subwoofer reproduction of bass keyboards etc which put out a more or less continuous tones.
If you have seen an FM radio station where the VU meter was stationary (full compression), one usually has a peak to average ratio between 6 to 10dB, that is the peak values were 4 to 10 times the average level.
As it is the average level which corresponds most closely with our perception of loudness (all other things equal), one can see the mechanism of compression, it brings up the average level by bringing up the lowest levels most.
In what many would consider audiophile recordings, the peak to average ratio is more like 10 to 20dB and occasionally into the 30’s (dB of peak to average). Now, producing music with a 20-30dB peak to average, at a fixed perceived average loudness, requires 100 to 1000 times more power than the average level.
I have a fireworks recording that has about a 40dB peak to average ratio, where the very short peaks are about 10,000 times more powerful than the average level. This recording eats up headroom like nobody’s business and so hard to reproduce with speakers I urge people to try good headphones first.
Lastly, everyone knows what clipping sounds like right?
Did you know that if the clipping is short enough you can’t hear it as a flaw and aren’t aware of it?
It is true, you usually can’t hear instantaneous clipping as a flaw, it is undetectable unless it lasts long enough ….OR you compare it directly to an unclipped signal. Then, the clipped signal sounds less dynamic but that’s all.
It is one thing to assume that because you can’t hear an overt flaw, that nothing in the signal chain is clipped and affecting the system dynamics, but it is another to take an oscilloscope and set it to look at the highest peaks coming out of the amplifier and see if they are clipped off at the top or bottom.
Best,
Tom Danley
Danley Sound Labs
Bring back mst3k and futurama
Old 27th January 2012, 06:31 PM   #115
Mooly's Avatar
I think where many are getting really confused in all this is in the basic concept of thinking of an amplifier as "putting out" say 10 watts RMS when in fact it puts out a voltage that (hopefully) is unaffected by loading. We equate that voltage to so many watts into 8 ohms.
Tom... if the pink noise comes off CD (and same for the fireworks recording) the absolute maximum peak level is known and can be translated into an equivalent "xxx watts into 8 ohms" amplifier is needed.
And then we make assumptions... and that is what this thread is about, a simple ball park figure for the amplifier power rating.
So can that amplifier maintain that "voltage" into the speaker at any frequency ?
Approx 28vrms into 8 ohms is 100 watts.
But the speaker isn't 8 ohm it varies. If the amp can maintain 28 volts though how do we now describe the power at other impedancies that the amp sees as the frequency varies. 28 volts at 3 ohms (some nominally 8 ohm speaker go down to that) is around 262 watts if the amp maintains it's voltage. But is that real power dissipated in the speaker ? or part reactive or apparent power. How does that affect the amplifier that is trying to maintain that voltage.
That's where something like this test moves into more case specific for known and specified equipment.
I think a test like this is genuinely useful and highlights how for the most part just how little "power" or voltage swing is needed.
This is going to run and run isn't it
Old 27th January 2012, 06:35 PM   #116
Brett is offline Brett
Brett's Avatar
Many posts back I made a comment on dynamic range in recordings, based upon an old Bob Cordell test. I found the page in wayback here
"This demonstration was a real "Wow" for the attendees. The Rickie Lee Jones (RLJ) cut was played at realistic, but certainly not unpleasant, levels in the relatively small hotel exhibit room on speakers with an estimated sensitivity of about 89 dB. The average power typically read 1-2 Watts, while the power on peaks often topped 250 Watts (the power display monitored only one channel, so these numbers should be interpreted as Watts per channel). On this cut, most peaks occurred with an aggressive thwack to a snare drum positioned dead center.
While it is true that the RLJ track has an unusually large dynamic range, this data still suggests that many listeners may be clipping their amplifiers more often than they think. This may especially be the case for those with tube amplifiers who are not using extraordinarily efficient speakers."
I agree with your comment that many well recorded albums can have dynamic range of 20dB or more, and movies can certainly add 20-30dB from dialogue (~ average) to loud SFX so I think many here are seriously underestimating the power they need if they never want to clip.
If I were to assume the 6V (5.7W at Re=6.3Ω) I mentioned in an earlier post was actually an average to get a never clip 20dB peak above that, I'm looking in the 600W class for amps.
Old 27th January 2012, 06:46 PM   #117
Pano's Avatar
your calculations say that the peak power is twice the rms power +3db but this is not the case.
Yes it is the case. A sine wave has a peak voltage that is 3dB higher than its average (RMS) values. There is no doubt about that.
Do you think you made a mistake in the test when you measured 7V on the test tone?
Correct. See the assumption in the first two posts and what Mooly says above. If you have done the test correctly, then you have measured a test tone that is 12dB (RMS) below the highest peak voltage that you ever use. You have just determined your peak voltage - at least for digital playback. The level will never go higher than that peak, unless you turn up the volume.
What would be the highest, unclipped sine wave value at your volume setting?
9dB above where you measured. Simple.
You now know the maximum voltage, and thus power, you need to play at your loudest setting. So you could say "OK, my 25W amp won't clip even when I play really loud, but it is right at the limit".
How do you know you have a 25W amp? You could measure it. Or you could take its advertised rating and reduce it a little, or a lot, depending on high much you think the marketing department has inflated the figure.
Rod Elliot has a good and funny page about amp power ratings here: Amplifier Power Ratings
Old 27th January 2012, 06:55 PM   #118
Pano's Avatar
I don't follow. Where is the 6V coming from? Is that what you need to get -20dB RMS at your listening level? Seems rather high, but possible.
If so, that indicates 60V peak, or 450W peak into 8 ohms. Or an RMS rating of about 225W into 8 ohms.
Old 27th January 2012, 07:00 PM   #119
Brett's Avatar
Sorry, I don't get this. You could easily have set the RMS of your test tone at 30dB down, adjusted the gain to get it to the same level. Then used that measured voltage as an average and known you would still be capable of peaks nearly 30dB higher than that, as they would not have reached 0dBFS.
Setting the level to -12dB is not realistic for potential program material.
I have a jazz disc somewhere here (I don't like the music) that noodles along at a modest level, which if I set it for a comfortable level at the LP (average of 80dB or so) is nice. Then all the horns come in at once and the difference on that initial note is easily >20dB, based upon your 9-12dB difference, artificially set, then I would be easily into clipping.
Old 27th January 2012, 07:13 PM   #120
Pano's Avatar
Brett, don't be misled by average music levels and the test tone. Only the test tone level is important for the calculations. I could have set it at -3dB or at -33dB. As long as you know what the level of the test tone is - you can calculate the maximum level.* It isn't complicated.
*at the volume setting you used to measure the tone.
A Test.  How much Voltage (power) do your speakers need?Hide this!Advertise here!
LM3875 power up test.. and it crackles w/o speakers attached? Keyoke Chip Amps 9 2nd March 2012 02:39 AM
how to test chokes for current and voltage speakerfritz Tubes / Valves 10 20th October 2010 12:32 PM
Aleph 30 problem - half of power supply voltage on speakers output yoke Pass Labs 18 15th March 2009 06:18 PM
How to test speakers? zaydenam Multi-Way 2 27th August 2008 02:02 PM
Test speakers? Ryssen Multi-Way 3 2nd March 2004 11:54 PM
