| View Poll Results: I measured the test tone at: | |||
| 2 volts or less |
105 | 38.04% |
| Between 2-5 volts |
97 | 35.14% |
| Between 5-10 volts |
32 | 11.59% |
| Between 10-20 volts |
16 | 5.80% |
| Over 20 volts. |
26 | 9.42% |
| Voters: 276. You may not vote on this poll | |||
#771 |
Uh oh. I think I've started the watt war, or people are getting fooled by watts.
200W allows me to hit dynamic peaks cleanly at 10dB more (about twice as loud) than my 20W bedroom amp. It has little to do with perceived loudness level (or as some people have asserted, a need for my apparent deafness :-P) We typically listen with only about 0.01-2W. (-20dB, to +3dB of the rated x dB/2.83V sensitivity of our speakers) Not 6 zeroes. Last edited by tktran303; 6th December 2012 at 02:41 PM. |
#772 | |
90 dB/W Vs 70 dB/'x'W = 2^[[90-70]/3.01] = 0.01 W 200 W would limit it to ~3 dB of dynamic headroom before subtracting in any loss over distance. Not sure how you're arriving at max audible range of recorded music in room since ~ -69 dB is relative to 0 dB and a quiet room will have a noise floor of around 40 - 50 dB. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#773 |
I got interested in amplifier power after purchasing a little 2020A amp to drive my computer speakers. I was so impressed withthe sound, I connected the amp to my large, vintage, 15 inch Tannoys, not expecting to much.
Anyway, the little amp has replaced the McIntosh 6100 I was using and I love it. The 2020A amp is only rated at a couple of watts into 15 ohms but it is not wanting for volume, clarity and attack. Bernstein's recording of Stravinsky's Rights of Spring just sounds amazing, the soft parts are soft and the loud parts make me jump. The test show 0.4v which calculates out at .085 watts for my 15 Ohm speakers. What am I missing here, is it that modern speakers are so inefficient and is my old treasures seem to be better than money in the bank? |
#774 | ||
If we now send a high power pulse of around 100Wpk that should generate an SPL that is +20dBW above the 1W reference level. But we know that speakers suffer power compression. To achieve an actual SPL level equivalent to +20dBW we would need to send more power, I assumed 3dB more power for 3dB of power compression at the 200Wpk level. Now the upper limit of our domestic system is +20dB and the lower limit of audibility is -69dB. This gives a range of audibility of 89dB. Last edited by AndrewT; 6th December 2012 at 05:03 PM. |
#775 |
Very rough and ready... One (as in not a pair) Celestion SL100 (efficiency 84db/w) and I could hear 2mv pk/pk 1Khz sinewave across the terminals at around 6 feet distance. The impedance at that frequency is 18 ohms. So the power is 0.000000028 of a watt.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#776 |
That is quiet. You have good ears and a quiet room !
Is that level -seventy odd dBW, or are you into the -80s? Last edited by AndrewT; 6th December 2012 at 05:34 PM. |
#777 | |
My little Farnell SPL meter shows around 25 to 30 dbc as the noise floor in the room the test was done.
#778 | |
The idea behind the test is to measure what you actually use. Most of us know the range we use on the volume knob. It isn't all that complicated. Sure, you need to pick some dynamic tracks, but that has already been stated - over and over. Find the highest point you ever use on the volume knob and measure there. Everything else will be equal to, or below that. |
#779 | |
| LM3875 power up test.. and it crackles w/o speakers attached? | Keyoke | Chip Amps | 9 | 2nd March 2012 01:39 AM |
| how to test chokes for current and voltage | speakerfritz | Tubes / Valves | 10 | 20th October 2010 11:32 AM |
| Aleph 30 problem - half of power supply voltage on speakers output | yoke | Pass Labs | 18 | 15th March 2009 05:18 PM |
| How to test speakers? | zaydenam | Multi-Way | 2 | 27th August 2008 01:02 PM |
| Test speakers? | Ryssen | Multi-Way | 3 | 2nd March 2004 10:54 PM |
