A Test. How much Voltage (power) do your speakers need? - Page 58 - diyAudio
View Poll Results: I measured the test tone at:
2 volts or less 220 38.39%
Between 2-5 volts 184 32.11%
Between 5-10 volts 77 13.44%
Between 10-20 volts 39 6.81%
Over 20 volts. 53 9.25%
Voters: 573. You may not vote on this poll
Old 22nd February 2012, 03:17 AM   #571
a.wayne is offline a.wayne  United States
Sin Bin
Bingo .....
They are all good 5th , one needs to watch the movie snatch 10 times , funny you should catch all of them seeing ur familiar with brick top's sarcasm ....
Old 22nd February 2012, 06:03 PM   #572
weltersys's Avatar
Originally Posted by 5th element View Post
At least from what I've gathered weltersys drives things hard and uses lots of power. If he were to use a full scale sine wave then things might start exploding
I have (accidentally) used a 60 Hz 120 volt sine wave (probably more square than sine, the amp was clipped and limited) for distortion tests with a four ohm B&C18SW115-4 speaker with no "explosions".
A much lower level than that did cause a pair of AR voice coils to continue travel in to the magnet structure after separating from the cone when the spider bottomed against the frame, made surprisingly little noise.
Art
Old 22nd February 2012, 09:21 PM   #573
Pano is offline Pano  United States
Pano's Avatar
Peavey used to do the "plug it into the wall" demos with one of their speakers. Of course its impedance peak was right at 60Hz. Still, an impressive trick.
Old 22nd February 2012, 09:26 PM   #574
Sin Bin
Originally Posted by Pano View Post
Peavy used to do the "plug it into the wall" demos with one of their speakers. Of course its impedance peak was right at 60Hz. Still, an impressive trick.
What you figured right around 800 watts .... what was the duration ?
Old 22nd February 2012, 09:38 PM   #575
Pano's Avatar
Not 800 (or 1800) watts because of the impedance spike at 60Hz. It might have been 140 watts. The demo wasn't long, cause it was LOUD. A good trick.
Old 22nd February 2012, 10:07 PM   #576
ra7 is offline ra7  United States
At such voltages, wouldn't you need insulated binding posts? None of that fancy gold plated stuff here
Old 22nd February 2012, 10:33 PM   #577
Pano's Avatar
Yes you do. There are some standards about that, tho I don't know what they are. Using Speakon connectors insulates you from that problem.
Old 22nd February 2012, 10:56 PM   #578
Default Peavy gets it right
I used to blame Peavy for driving me away from live shows. Chances are the entire audio chain was harsh in the 80's.
Old 22nd February 2012, 11:18 PM   #579
Sin Bin
Nah ... it was peavey .....
Old 23rd February 2012, 01:18 AM   #580
Default Peavey
I thought so. Thanks for the spell check. BachmanTurnerOverdrive came to town and I loved their "blue collar" song so I bought a ticket and went to the show and lasted maybe 10 minutes.
It's good to know that pro sound and hi fi are no longer enemies
LM3875 power up test.. and it crackles w/o speakers attached? Keyoke Chip Amps 9 2nd March 2012 01:39 AM
how to test chokes for current and voltage speakerfritz Tubes / Valves 10 20th October 2010 11:32 AM
Aleph 30 problem - half of power supply voltage on speakers output yoke Pass Labs 18 15th March 2009 05:18 PM
How to test speakers? zaydenam Multi-Way 2 27th August 2008 01:02 PM
Test speakers? Ryssen Multi-Way 3 2nd March 2004 10:54 PM
Copyright Đ1999-2017 diyAudio
