Old 17th January 2012, 11:43 PM   #1
Default Linkwitz Pluto + MiniDSP + ClassD
I've built the Linkwitz Pluto, utilizing a MiniDSP and cheap ($50) 4x100 @ 4ohms Sure TK2050 Class D board. The result is outstanding, even with the board a little under powered with a 24V SMPS. My plan is to upgrade to a few high quality classdaudio boards in the near future, enclosed in a nice chassis with a toroidal transformer.
I made a YouTube video. My cheap pocket camera does not do the accoustics justice, but you get the idea....
/Mason
Old 18th January 2012, 12:06 AM   #2
Speedskater's Avatar
While you can build a speaker that's similar to a Pluto, you can't build a Linkwitz Pluto unless you use all the Linkwitz parts.
Kevin
Old 18th January 2012, 12:17 AM   #3
Same drivers. Same filtering (via DSP rather than Opamps). Different amplifier. Not much difference, unless you want to split hairs in regard to branding. Linkwitz himself even suggests to use of DSP in his Linear Audio - Volume 0 article "STEREO - From live to recorded and reproduced - What does it take?"
Originally Posted by Linkwitz
"The active crossover/equalizer filter functions can also be implemented with a digital signal processor (DSP). This could potentially results in superior loudspeaker performance..."
I don't see a problem with updating the design with newer DSP technology and a quality Class D amplifier. The sound is still outstanding, to me.
Old 18th January 2012, 12:20 AM   #4
5th element's Avatar
Well if you use the same drive units and emulate Linkwitz crossover down to the last detail then you've got yourself a Pluto imo. How you implement the xover (providing the filters are the same) is irrelevant, as is the amplification.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 18th January 2012, 02:17 AM   #5
kevinahcc20's Avatar
To quote SL, "The function of the ASP could be duplicated with a digital signal processor, DSP, by realizing the poles and zeros of the different transfer functions, and following the same signal flow and gain distribution. Still great care must be taken to have enough dynamic range for each number processing stage to minimize non-linear distortion. Such custom DSP design is not trivial and requires good firmware programming knowledge and technique." so no slam dunk unless the implemetation satisfies all of SL's caveats.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 18th January 2012, 04:49 AM   #6
Pano is offline Pano  United States
Pano's Avatar
I think it's cool. The Pluto is a nice sounding speaker. Glad to see someone do this.
Old 20th January 2012, 06:04 AM   #7
ScottG is offline ScottG  United States
Details please with respect to implementing the mini-dsp for this design!
perspective is everything
Old 20th January 2012, 04:05 PM   #8
KyleinCowichan's Avatar
He's clearly not trying to fob this off as some kind of exact copy of the Pluto. I think you need to lighten up a little. Also, he's working on this in his house for his own enjoyment so he can call it whatever he wants. Dragging this thread into the dank and miserable depths of a semantic argument about what he can and can't refer to his speakers as is the definition of trolling.
Mason - That's really cool. I just bought a miniDSP and I am very interested in seeing other peoples results programming it. My first try at it was replicating the crossover in my Overnight Sensations. I think it was fairly successful! Perhaps you could post some screen shots of the plug-in settings?
Kyle
Old 20th January 2012, 04:21 PM   #9
Davey is offline Davey  United States
It's difficult to match transfer function curves by scaling photographs and estimating.
Mason supplied the .xml file (originally from Kentaro) to everyone on the Orion Users Group. (Still there and anyone can download it.) I loaded it into my miniDSP 2x4 and unfortunately it doesn't match the curves created by a real Linkwitz Pluto ASP.
Kyle,
We try to follow the lead/direction of Mr. Linkwitz for DIY projects like this. He ENCOURAGES this type of project/experimentation, but he only requests that the builder not name the project "Pluto" or "Orion" or whatever. These are projects where the builder has not purchased Construction Plans or circuit boards and/or compensated Mr. Linkwitz in any way. I know this seems a silly concept to some folks involved with "DIY" audio. (Probably like holding back the wind, at this point.)
Dave.
Old 20th January 2012, 04:37 PM   #10
MrSlim is offline MrSlim  Canada
/Mason
Have a look at the L15D or L20D (2092 based Class D) threads, they are a nice economical ClassD solution that people are having success with..
MiniDSP as Linkwitz Orion ASP gainphile miniDSP 84 16th November 2011 01:13 AM
Linkwitz Pluto-alternated driver choice soundnovice Multi-Way 21 2nd November 2011 02:48 PM
FS: Major Caps Upgrade for Linkwitz Pluto Loudspeakers cuibono Swap Meet 6 7th May 2011 12:48 AM
alpair/jordan fullrange vs pluto linkwitz fxs Full Range 26 21st February 2011 08:07 PM
FS:Linkwitz Pluto Nikola Krivorov Swap Meet 0 2nd October 2009 08:44 AM
Page generated in 0.11466 seconds (81.37% PHP - 18.63% MySQL) with 10 queries
