Old 17th January 2012, 08:09 PM   #1
3GGG is offline 3GGG  Australia
Default Horn Build using a tapped horn as a frame??
About to order my horns from Poland, finally settled on a design, for the horns at least.
I need to do 30 to 100hz and a tapped horn is looking like the most feasible way to do so.
I think if i build the tapped horn (possible 2 metres tall and maybe 400 x400 mm with a suitably heavy base it would be possible to incorporate the tapped horn as the frame to mount the horns. Has anyone done so? Thoughts?
Old 17th January 2012, 11:52 PM   #2
I stack my mid/high horns on top of tapped horns, works fine as long as they are time aligned.
Dayton SD315-88 Tapped Horn Build killa12222 Subwoofers 11 15th June 2011 05:46 PM
Volvotreter 20Hz Tapped Horn build (pics) RadiantNRG Subwoofers 60 12th March 2011 07:18 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Page generated in 0.07269 seconds (72.46% PHP - 27.54% MySQL) with 10 queries
