Old 17th January 2012, 06:45 PM   #1
mrappe is offline mrappe  United States
Default Replacing a inductor/coil/choke on ESS AMT1B
I was re-capping my crossover with poly caps and had to drill a hole in the board and accidently caught one of the coils and broke some of the wires. I have put them back together and rewound it on a 1" wooden stick to form it but i would like to replace it with the same value. How can I find or make a replacement? I don't have the schematic and need to find out where I could find another coil or make one.
Old 17th January 2012, 07:05 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
You can measure the same coil on the other speaker, which would get you close enough. You would need some method of reactance measurement, or you could do it the "hard way" by noting current loss through the coil at different source voltages and frequencies.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 17th January 2012, 08:17 PM   #3
The only thing I have is a digital multimeter. If I measure the length of the wire and have the other dimentions and the ga of the wire would it not be equivalent?
Old 21st January 2012, 04:58 PM   #4
I found this site Special Edition Accurate LC Meter Kit with Green Backlight LCD - <font color=green>FREE CASE</font> - Electronics-DIY.com
This might be a good way to measure the other coil. Does anyone know anything about this meter?
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
ESS AMT1B Bookshelf problems. miklos Multi-Way 1 6th November 2010 09:08 PM
Help replacing a PSU choke - How to choose choke Hubba Tubes / Valves 2 10th September 2010 02:33 PM
Free ESS Heil amt1b cabinets-charlotte NC srinath Swap Meet 2 26th July 2010 08:30 PM
Coil Inductor Wiring TooManyToys Construction Tips 2 12th November 2009 10:19 AM
Page generated in 0.07527 seconds (69.89% PHP - 30.11% MySQL) with 10 queries
