photoshoot OB MK1, at least they sound good
Old 14th January 2012, 09:08 AM   #11
janikol is offline janikol  Russian Federation
Originally Posted by Helmuth View Post
15 inch woofers, xo passive
this 4 х "Eminence ALPHA-15A"?
Old 14th January 2012, 09:45 AM   #12
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
You could those to. Simulate it in hornresp.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 14th January 2012, 10:17 AM   #13
ALPHA-15A works up to 200Гц, all that is higher a dirty
Old 14th January 2012, 10:30 AM   #14
Helmuth's Avatar
Hi Janicol,
Here a simulation of the alpha 15A. With corner placement even 96dB 1wmtr 26Hz -3dB is possible. Simulation shows 1Phi placement .
File Type: png Schermafbeelding 2012-01-14 om 11.25.59.png (22.7 KB, 974 views)
File Type: txt alpha15a.txt (390 Bytes, 43 views)
Old 14th January 2012, 10:39 AM   #15
Helmuth's Avatar
This efficiency and sub-low in this compact design and low group delay, low phaseshift is unique. Only stupid people build a onken.
This design doesn't use the eminence alpha 15a
Old 14th January 2012, 10:46 AM   #16
It not news... It is impossible to allow alpha 15A to reproduce a vocal
What it is dynamics?
Old 14th January 2012, 10:51 AM   #17
Helmuth's Avatar
It will be the challenge to get a source 300Hz -20kHz up with a high efficient full-range, even nicer a compression driver.
Old 14th January 2012, 10:57 AM   #18
rvrazvan is offline rvrazvan  Romania
rvrazvan's Avatar
Nice! Congrats.
After horns my next target will be some OB BASS!
Old 14th January 2012, 11:29 AM   #19
Helmuth's Avatar
I can feel the punch. It is a efficiency effect IMO, dynamics is not direct to a horn related I am talking about low now.
Old 14th January 2012, 12:19 PM   #20
Draki is offline Draki  Macedonia
Nice!
What is the co point? And how much did you attenuate the CD? Resistors or autoformer?
photoshoot OB MK1, at least they sound goodHide this!Advertise here!
The Small, Cheap, Good, Easy2Build OB Juspur Full Range 5 8th June 2010 09:14 PM
Very pleased from DIY OB sound hifisucks Full Range 6 31st October 2009 10:35 PM
What makes the good guitar pickup sound so good? darkfenriz Instruments and Amps 15 2nd March 2009 12:46 AM
How To Get The OB Sound From A TLine Or Sealed Box?? Ben Reginato Multi-Way 17 10th May 2008 02:29 AM
