photoshoot OB MK1, at least they sound good - Page 3 - diyAudio
Old 14th January 2012, 11:27 AM   #21
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Originally Posted by Draki View Post
Nice!
What is the co point? And how much did you attenuate the CD? Resistors or autoformer?
570Hz, I did try C-core autoformer and resistors. I use now many parallel 2W metal-film resistors they sound the best and cost about nothing, wire wound sound harsh due inductivity.
The damping factor improves with the attenuation compared to direct connection to SE-tube amp.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 14th January 2012, 11:56 AM   #22
_henry_ is offline _henry_  Australia
helmuth,
that is very handsome.
what woofers are u using?
cheers
henry
Old 14th January 2012, 12:03 PM   #23
Helmuth's Avatar
Originally Posted by _henry_ View Post
helmuth,
cheers
henry
They aren't available in in indonesia. Janicol had a good example you could use they would do 2dB more if they meet the simulation, and are not expensive.
Old 14th January 2012, 12:09 PM   #24
? i was born in indonesia, but im hoping between china, philippines and aust. not ideal for the hobby, but what can i do
who is Janicol?
i've used alpha15 and beta15. Beta15 outperform alpha by miles. but ur woofer cones does look like alpha15.
cheers
henry
Old 14th January 2012, 12:13 PM   #25
Helmuth's Avatar
who is Janicol?
cheers
henry
You have experience enough.
Old 14th January 2012, 12:43 PM   #26
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
I'll try to ask ...........
Helmuth, what compression driver you used?
flesh flash flush
Old 14th January 2012, 12:53 PM   #27
Helmuth's Avatar
Beyma cp750ti then you have to select the right one. Just stock has to huge tolerance Hifi application
Old 15th January 2012, 05:19 AM   #28
Flaesh's Avatar
clear
and
Originally Posted by Helmuth View Post
a 2inch driver a Paudio ..
puzzles me
flesh flash flush
Old 15th January 2012, 07:08 AM   #29
DQ828 is offline DQ828  Australia
DQ828's Avatar
Very nice work Helmuth.
Old 15th January 2012, 08:08 AM   #30
Helmuth's Avatar
clear
and puzzles me
2" paudio horn not driver.
The Small, Cheap, Good, Easy2Build OB Juspur Full Range 5 8th June 2010 08:14 PM
Very pleased from DIY OB sound hifisucks Full Range 6 31st October 2009 09:35 PM
What makes the good guitar pickup sound so good? darkfenriz Instruments and Amps 15 1st March 2009 11:46 PM
How To Get The OB Sound From A TLine Or Sealed Box?? Ben Reginato Multi-Way 17 10th May 2008 01:29 AM
Copyright 1999-2017 diyAudio
