Okay, so I'm just figuring out this whole thing. I've started by trying to figure our crossovers.
My first question is this: If a crossover requires a 1.00 mH - 0163mm (#14AWG), is the "0163mm" part relevant? What does it mean? Will any audio grade 1.00 mH air core inductor work? Sorry for being so damn ignorant. |
#2 |
Based on the gauge of the wire, inductors have different resistances that designers take into account when developing a crossover. The "thicker" the wire, the less resistance it should have.
#3 |
It appears the 0163mm is the wire diameter measurement equivalent to 14 gauge (AWG) wire. From the table here:
American wire gauge - Wikipedia, the free encyclopedia 14 gauge is 1.628mm in diameter. I don't know why it's "0163" instead of 1.63. |
#4 |
Thanks. Great link.
It is weird that it appears to have the wrong mm specification for #14 AWG. So I assume that a copper foil 1.00 mH inductor (even if its #14 AWG) would not work since the resistance would be different? Or is copper foil supposed to be the same if it has the same AWG rating? Fun fun fun |
#5 |
Unfortunately, manufacturer differences result in different DCR's, even for the same gauge. If you are designing your own crossovers, you have to use the resistance of the inductors you have, or are planning to purchase. If you are building someone else's design, they usually specify the DCR used. If it's not significant to the design, they sometimes just specify the gauge - it will be close enough.
| Noob with questions... | Tristanc1 | Chip Amps | 6 | 23rd September 2006 10:17 PM |
| Noob questions | deriver23 | Car Audio | 1 | 25th August 2006 11:06 PM |
| Few noob questions | Richie V6 | Chip Amps | 1 | 7th December 2004 05:02 PM |
| Page generated in 0.07993 seconds (72.48% PHP - 27.52% MySQL) with 10 queries |
