Hi
Is it possible to digital time-align a multiway dipole in both the front and back-direction? I.e. if one time-align the speakers for the front output of the elements, will they then also be time-aligned for the back output? (I presume the answer is no...) Br Gisle |
#2 |
You presume right! At least to my way of thinking.......
John K has an excellent explanation here: Dipole-offset Been a while since I read it, but if I remember right he considers the baffle to be the acoustic center. This is something I've been wondering about lately, as I have 4-way dipoles, with 3 drivers suspended 'naked', and the woofer in a shallow u-frame. When measuring and setting xo's and looking at phase alignment, having the drivers in line where the baffle would be does not result in time alignment, in the forward or backward planes. I can adjust the drivers offset on Z and get good alignment to the front, but the rear goes to hell.......... What's more important, good time/phase alignment to the front, or equal response front and rear? |
#3 |
I have tried to explain my view on the best time alignment here. Don't forget to follow that discussion down the page.
In general I would put emphasis on the direct response (front output), but try to keep the back output free from VERY deep notches. Rudolf
www.dipolplus.de |
#4 | |
John k.... Music and Design NaO Dipole Loudspeakers. |
#5 |
On thing that further complicates things is the front/back symmetry of the radiation of different drivers.
This will give you headaches in the crossover regardless how well ACs are physically aligned unless you use "true" dipole drivers (planars) and/or sufficient ways(probably 4 way at least), otherwise what will look like a very linear response in the front might be total mess in the back due to different roll-offs, etc. I think in the end it's all about a reasonable compromise.
I don't believe in audio believings. Last edited by bzfcocon; 12th January 2012 at 11:22 AM. |
#6 |
Thanks for all the answers!
I will try keep/obtain timecorrection through physical alignment Br Gisle |
#7 |
Thanks for the link Rudolf, I had forgotten about that thread over there...........and now I need to revisit my driver spacing this weekend!
Audiodidakt - what's the configuration of your speakers, drivers, baffle, etc..... |
#8 |
Last edited by natehansen66; 12th January 2012 at 11:02 PM. Reason: removed double post |
#9 |
Currently I have no set-up; only spare parts... :-) Those are:
Mundorf AMT2510 (?) tweeter - will be hanging without baffel Scan-Speak Illuminator 18 med - will be hanging without baffel Precision Device PD15something - will be in baffel, probably in a cardioid-config. I have AE TD15M comming in, taking the PD's place. From about 125 Hz and below I am currently searching for the "best" option. It might be a solution with 4 woofers in a "multi-sub" config. XO through MiniDSP Br Gisle |
#10 | |
| I need help with digital Room-correction | Radian | Multi-Way | 1 | 7th February 2007 07:10 PM |
| time correction and units alignment | Williams Audio | Multi-Way | 48 | 21st October 2006 03:19 PM |
| Time advanced error feedback correction | smoking-amp | Tubes / Valves | 25 | 13th November 2004 03:24 AM |
| Page generated in 0.11649 seconds (78.63% PHP - 21.37% MySQL) with 10 queries |
