I'm considering an open baffle project and am trying to sort out a few things. I've read numerous accounts of active equalization vs passive, complications with matching the levels of the mids/tweets and the woofers, baffle width, quarter waves, dipole null, etc, etc.....
I'm considering a 'beginner' project. I'd like to start by taking the drivers from a pair of JBL HLS-610 or boston vr-940 and mounting them on a baffle (probably 20"w x 38"h) and then I'd like to blend them in with an Eminence Alpha 15. I intend to Bi-amp. Has anyone tried this? I can't easily find the T-S parameters of the 'donor' drivers, so i'm really taking a shot in the dark. I know the baffle widths of the donor cabinets are much less than 20" and I'm guessing the donor crossovers are simple 12db/octave crossovers. What are the major problems with this approach? |
#2 |
You need to be able to measure anyway, so no problems at all. It don't have to be expensive. This is a full calibrated system for 148 €
http://www.kirchner-elektronik.de/gb-atb-pc-pro.php - I think you have to multply with 1,3 to have it in USD but no quite sure. Or you can download Holm Impulse for free HOLM Acoustics And use a cheap selfmad mic based on panasonic WM61 capsule Home Theater - Image Gallery - Panasonic Microphone wand Then you are ready for less than 20 USD. Last edited by Kjeldsen; 9th January 2012 at 07:44 PM. |
#3 |
OB produces a dipole in ambient emission ( sound propagation ).
So that's , I think , the main feature . The back wave of the speaker / system is not controlled / attenuated by the cabinet ,but by the room . |
| Does open baffle suffer from baffle step? | 454Casull | Multi-Way | 15 | 19th May 2012 03:12 PM |
| Upwards aligned open baffle? ( pop box meets open baffle ) | OllBoll | Full Range | 3 | 28th March 2011 01:00 AM |
| Murphy baffle radios [ open baffle ] | keithpeter | Full Range | 10 | 11th September 2007 07:59 PM |
| what effect does baffle have on open-baffle system? | kappa546 | Multi-Way | 6 | 24th January 2006 10:21 PM |
| Australians- what solid timbers for baffle? (open baffle loudspeaker) | tktran | Multi-Way | 13 | 29th November 2004 11:09 PM |
| Page generated in 0.12562 seconds (43.74% PHP - 56.26% MySQL) with 10 queries |
