Old 9th January 2012, 01:33 PM   #1
Einric is offline Einric  United States
Default Drivers In Series
OK, I see everywhere that two drivers in parallel will net 3db gain.
What about series connection?
Do you get the same 3db because you are doubling the radiating area?
Old 9th January 2012, 01:57 PM   #2
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
2 drivers will always have 3dB of sensativity gain over a single driver when compared with equal input wattage regardless of how they are wired. The difference is that, when they are wired in series, it will take twice the voltage to reach the same wattage as it will if they are wired in parallel.
With equal voltage input, wiring in series will result in a 3db sensitivity gain and a 3dB power loss compared with a single driver, resulting in no change in output with half the power consumption.
With equal voltage input, wiring in parallel will result in a 3dB sensitivity gain and a 3dB power gain compared to a single driver, resulting in a 6dB increase in output with twice the power consumption.
Old 9th January 2012, 10:17 PM   #3
Hi, Yes, but with the caveats as stated in post #2, rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
LPF for one of two drivers in series RevMen Full Range 11 6th December 2011 03:15 AM
4 ohm drivers in series w/ crossover Einric Multi-Way 3 4th June 2011 07:31 PM
Compound Isobarik, Drivers in series vs // pheonix358 Multi-Way 14 29th December 2008 11:58 PM
X/overs with 2 drivers in series Q?'s rolfy72 Multi-Way 4 8th October 2003 04:38 PM
Drivers in series - ok or bad? Circlotron Multi-Way 14 28th October 2002 04:15 AM
Page generated in 0.07096 seconds (69.72% PHP - 30.28% MySQL) with 10 queries
