If you had 0 -0 to spend what Midrange/midbass would you buy?
Old 17th September 2003, 05:01 PM   #1
jainbaby is offline jainbaby  United States
Default If you had $150 -$200 to spend what Midrange/midbass would you buy?
If you had $150- $200 per driver for Midrange/midbass drivers what would you buy?
I want to build a 2 way floorstanding speaker. I do not want to use a driver bigger than 7 inch.
after I figure out driver than I will work on tweeter. As far as tweeter it will definetly be silk dome.
any and all suggestions would be great.
Old 17th September 2003, 05:35 PM   #2
On Hiatus
SY's Avatar
Default $150-200
Is that per driver or for a pair of drivers?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th September 2003, 05:53 PM   #3
Per driver. I have about $400 to spend on the Midrange/midbass drivers
Old 17th September 2003, 06:19 PM   #4
On Hiatus
SY's Avatar
If deep bass isn't a priority (maybe you'll set up a sub later), the 15W/8530K-00 from Scan-Speak is superb. It will be easy to control dispersion at crossover if you match it with a tweeter suitable for a 3K or so crossover point.
Old 17th September 2003, 06:23 PM   #5
OK,
I have a Rel sub. So I am ok for deep bass.
Any other suggestions?
Old 17th September 2003, 06:53 PM   #6
316a is offline 316a  England
316a's Avatar
Default Jordan
Originally posted by jainbaby
OK,
Jordan JX92S should do the trick . This is an aluminium-coned full-range/wideband driver , partner it with a ribbon or electrostaric tweeter and they're unsurpassed (to me!) for their $110 pricetag. Hope this helps
316a
Old 17th September 2003, 07:12 PM   #7
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
I can recommend the SEAS W18EX001 (E0017) or some of its cousins
Mads K
Old 18th September 2003, 08:41 AM   #8
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Jordan
That's what i was going to suggest when i saw the thread title.... and if you need something a little more efficient the Fostex FE168ES is worth a look.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
If you had 0 -0 to spend what Midrange/midbass would you buy?Hide this!Advertise here!
Seas Nextel 7" New W18nx-001 Midrange/midbass Pair newtitan Swap Meet 2 25th April 2007 08:22 PM
WTB: Accuton Midrange/Midbass drivers sbrtoy Swap Meet 1 3rd April 2007 02:00 AM
FS: Audax AP170Z0 and Seas P17REX Midbass/Midrange Drivers omarmipi Swap Meet 3 23rd April 2006 12:32 AM
6.5" midrange/midbass recommendation VinceV Car Audio 0 4th March 2006 08:19 AM
JM Labs & Focal - Centre channel / Difference between Midrange & midbass speakers mark.carline Multi-Way 5 18th May 2004 07:03 PM
