Would the screw inserts for spikes attach better to plywood or MDF?
Am doing a pair of ZRTs (2.5 way, sealed) in MDF, and have some plywood cut out ready to be sandwiched with either the internal bracing or the bottom panel.
-Tor |
#2 |
Tough decision. I'd think the MDF would make a cleaner insertion hole but that the ply would be more durable. Assuming that the spikes will be in the base panel which will be holding the whole unit, I think I'd prefer a quality plywood panel.
#3 |
I found some supporting opinions for plywood here; Proper Screws for MDF - by John R. @ LumberJocks.com ~ woodworking community.
My plywood is not of marine quality though.
-Tor |
#4 |
Probably depends as much on the inserts as the core materials - thread spacing/ pitch angle depth can vary quite a bit on these.
While it may seem to go without saying, care must also be taken to pilot hole the correct size - too large and the thread won't bit deeply enough to guarantee against the wobblies - too tight and they will be an absolute bitch in screw in all the way, and particularly the Zamac etc softer cast inserts that are installed with hex key can snap before you're done. Good luck getting those out. That said, good quality multi-ply has better thread holding properties than MDF.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#5 |
Use Plywood - i've had spike inserts break in my martin Logans request bottom - they used rather cheap mdf
| Plywood or MDF? | greg_mcquaid | Subwoofers | 30 | 10th July 2011 06:37 AM |
| Observation Plywood vs MDF OB | kaybee | Full Range | 20 | 11th November 2006 01:45 AM |
| Method for attach fiberglass to MDF walls | JC Fardo | Multi-Way | 7 | 13th April 2005 07:32 PM |
| MDF v Plywood construction | greenie512 | Multi-Way | 48 | 19th February 2005 02:16 AM |
| plywood instead of MDF? | jdeare | Multi-Way | 2 | 21st February 2003 12:36 PM |
| Page generated in 0.08252 seconds (70.17% PHP - 29.83% MySQL) with 11 queries |
