Hello everyone,
After some research I have came up to a conclusion to use the following drivers for the next project : visaton's aluminium cone woofer AL170 & ceramic tweeter KE25SC. It is a bit difficult to blend them because the woofer shows resonances at ~6 kHz and tweeter's distortion rises below ~2kHz. I have considered a 24db/oct crossover at ~1.6 kHz with a notch filter for the woofer. If tweeter and woofer is wired out of phase in simulations I get good FR and -5 db spl for both at crossover point. However off-axis response(mainly > 40 degress to top) shows large(~15 db) dips at ~1.6 kHz. I can wire both drivers in phase. Then after adjustment of components I get quite good frequency response from 0 to ~60 degress off axis, but both drivers must produce something like 5 db more at crossover point, so I expect distortion of both will be higher. My question is what is more important : better power response(i.e off-axis SPL) or few db less THD? Maybe someone has real-world experience with it ? |
#2 |
i'm avoiding woofers with hf peaks.
and my speakers with exessive headroom allow me to not think about such trifle as spl and distortion.. stupid way. but working goood.
flesh flash flush Last edited by Flaesh; 7th January 2012 at 10:27 PM. |
#3 |
Theoretical responses with the drivers out of phase is a very bad idea. A consistent out of phase dip = a consistent in phase response off axis. Stupid cancellation at the c/o point never works well, ever. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#4 |
I think the improved power response looks best, although I don't do it that way myself. At the least, why don't you try to get the phase just so on axis, that the notches will be pointing at the floor and ceiling.
#5 |
Put a zobel circuit on the woofer, 8-10 ohm and 20 uF. Say goodbye to the 6 kHz peak.
#6 |
On re-reading my post, I'd like to clarify a point. Having the drivers in phase on-axis will centre the main lobe. The way you've done it with the flatter looking power response probably has a deep notch just slightly below axis. Try running top to bottom.
| Active high dynamics/SPL & high performance loudspeaker system for my living room…! | Robert GS | Multi-Way | 53 | 11th April 2012 05:12 AM |
| OT: how can I measure THD of my amplifier if my sound card is 0,02% THD ? | ygg-it | Solid State | 1 | 13th June 2010 07:54 AM |
| How do I maximize piezo audiable SPL for an alarm system? | Aoxomox | Planars & Exotics | 18 | 19th February 2010 10:23 AM |
| Best off-axis drivers? | Spasticteapot | Multi-Way | 7 | 28th December 2007 10:40 PM |
| SPL@2.83V or SPL@1W ? what is right? | Astro Power | Subwoofers | 6 | 29th December 2005 10:58 AM |
| Page generated in 0.08591 seconds (73.82% PHP - 26.18% MySQL) with 11 queries |
