Hi all,
I'm working on a hi-fi system for my home listening. I have an old SONY MHC Series Sound System. Uses an STK4191. I hate the sound of that system. The sound starts booming when i increase the volume. Before it was my mistake that I had kept the system very close to the wall. Around 1" away from the wall. Now it as around 8"-9" away from the wall....and it still boom...aargh! I'm using the Speakers and Tweeters from the SONY System to make my new pair of speakers. It has 2 x 6" SONY Woofers [6 Ohm each] 2 x 4" SONY Tweeters [4 Ohm each] BOTH MADE IN MALAYSIA. My new sound system will have. 24 dB/Octave 2-Way Linkwitz-Riley Electronic Crossover 2 x LM3886 [For Hi frequencies] 2 x P3A [For Low Frequencies] Now comes the part of the Box-Design. Added the blueprint of my design idea. Please comment. This is my first build, so I have NO IDEA whether I'm on the right path or not. Please guide me further.... Thanks and Regards |
#3 |
sreten is quite right that you need a bigger box for those bass units to avoid the boom. Maybe some damping material too. You could even plug tennis balls or something in the ports and see if it helps. Typical Sony MHC are speakers with big ports and small boxes by the look of them. You might call them BOOM boxes!
![]() 4 and 6 ohms and unknown qualities makes it hard to know where to go. But for sure, if you use a bigger sealed box, that reduces the overall bass peak. Morgan Jones explains bass resonance very well in his Arpeggio speaker design: Arpeggio Loudspeaker See if you can figure out the crossover wiring, which I'd suspect is just a capacitor to the tweeter unit, and whether it is putting the speakers in series or parallel. Also whether the tweeter has its own enclosure. Might be easier to suggest something then. Good luck with this. You can often get quite a good and lively sound with cheapish drive units. |
#4 |
You can't design a box unless you know the parameters of the speakers, you need to measure them, that's easy: make a simple jig, download ARTA
ARTA Download, start measuring Then download Unibox UniBox - Unified Box Model for Loudspeaker Design - Kristian Ougaard & design your box
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#5 |
HA ah ,Peter ,
I was searching in the site when I encountered your TL-Karlson 3 way. Pretty Ugly ![]() |
#6 | |
You've got perfectly flat drivers that extend from 0 to infinity without their own transfer functions, with the same acoustic center and identical sensitivities?????? The above speakers are made in malaysia sony speakers. You've got an infinite baffle on which to mount these speakers. You've got different amps with different input sensitivities and gain structures. Um... maybe you should reconsider. |
#7 |
re:'I encountered your TL-Karlson 3 way' - that's ancient history, they don't exist any more
| Hi-Fi system build | DMoe | Tubes / Valves | 13 | 28th December 2007 07:41 PM |
| Class D is nonaudiophile, not hi fi system, they are saying that! | destroyer X | Class D | 58 | 12th March 2005 09:23 PM |
| Singing through the Hi-Fi system?? | The Rocker | Instruments and Amps | 3 | 14th February 2005 04:27 PM |
| Can you enjoy music on a low fi system? | Bricolo | Everything Else | 44 | 24th February 2003 11:03 PM |
| Page generated in 0.10735 seconds (80.75% PHP - 19.25% MySQL) with 11 queries |
