For the last 4 years I've had a 2-way line array loudspeaker in my system consisting of eight ScanSpeak 18W/8531G-00 midbasses and eight Fountek NeoPro 5i ribbons in a sealed enclosure. F3 is 60Hz, so I augment with stereo subs. I greatly enjoy the music they make and they are "keepers", but I must move to a smaller living space which cannot accomodate the subs. I'd like to simplify in any event. My crossovers are outboard, making life a bit easier. I have no experience with enclosure design, and ask for guidance regarding the feasiblilty of building new transmission line cabinets for my arrays. Manufacturer specs for the ScanSpeak 18W/8531 lists a Qts of .36 which, hopefully, is transmission line friendly. I've no experience with enclosure design and will seek a cabinet builder for the actual changeover. If bass reflex has merit, I'd surely consider. I assume no crossover modification will be required, but let me know if I'm mistaken. All help is greatly appreciated!
#2 |
Have you seen this article?
#3 |
frugal-phile(tm)
Any transmission line is going to be larger than a sealed box (assumming the same number of drivers). An Alpha line uses a larger than necessary box, and lots of damping to simplify the design algorithm for these TLs.
A more optimum TL can be designed using all the tricks. To get a smaller box you are going to have to use fewer boxes. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Thanks for the responses. Increased depth of the enclosure versus sealed will work in the new room.
| 3 way transmission line enclosure | SamClassA | Multi-Way | 10 | 5th June 2011 12:36 PM |
| Transmission line loudspeaker cabinets | R-Carpenter | Swap Meet | 0 | 23rd July 2009 03:22 AM |
| line array + transmission line ? | zobsky | Multi-Way | 12 | 16th August 2006 04:18 PM |
| proposed transmission line array | kneadle | Multi-Way | 12 | 25th July 2004 09:19 PM |
| how to combine Line array and transmission line together | Jared | Multi-Way | 5 | 19th April 2004 10:32 PM |
| Page generated in 0.06063 seconds (81.48% PHP - 18.52% MySQL) with 10 queries |
