New cabinets for Altec 416a
Old 4th January 2012, 11:11 AM   #1
angeloitacare is offline angeloitacare  Brazil
angeloitacare's Avatar
Default New cabinets for Altec 416a
i got recently a good deal of two pairs of altec 416a's. Since i heard Onken W's in italy, it was my wish to try out something similar in my system. Today i came up with this drawing. With these dimensions, internal cab volume is about 300l.
Any comments ?
Old 4th January 2012, 08:40 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Is it a sort of rear loaded horn?
Old 4th January 2012, 08:43 PM   #3
Yes, something between a backloaded horn, and bassreflex.
Old 4th January 2012, 08:47 PM   #4
Pano's Avatar
OK, that what it looks like - a combo. Maybe GM will have something to say. I have no idea how well it would work.
Old 4th January 2012, 09:27 PM   #5
cyclotronguy is offline cyclotronguy  United States
Default Horn
Hmmmmm Altec meets RCA.
Old 5th January 2012, 07:01 AM   #6
Jmmlc is offline Jmmlc  France
R.I.P.
Hello Angelo,
Without numbers it is hard to say but the frequency at which the vents tune the box seems to be very different than the cut-off of that truncated horn. I'll imagine the horn will provide no acoustic load at that tuning frequency.
In conclusion apart the shape of inner volume of the box which seems good in reducing internal reflections, the enclosure as it is designed will act purely as a bass-reflex.
(But it is a nice Onken-Jensen style bass-reflex) .
Best regards from Paris, France
Jean-Michel Le Cléac'h
Old 5th January 2012, 07:25 AM   #7
Originally Posted by Jmmlc View Post
Hello Angelo,
Hello Jean-Michel
the primary idea is to use it indeed as bass reflex, just in a different shape than the regular Onken enclosure, to meet my demands. Which are wider vertical dispersion through the vents , and mantain the internal volume of the Onken, to get similar performance. In that case would you suggest to take off the internal wave guiding walls, which would give a shape similar to a horn ?
Angelo
Old 5th January 2012, 06:02 PM   #8
Angelo
Given the tuning of the vents, I would expect very little if any vertical dispersion enchantments. Unless of course you make the thing tall enough with respect to it's environment to gain boundary loading effect... and then only at low frequency.
Then again we are discussing the mighty 416a, which while a very fine device; it is my no stretch of the imagination a low frequency transducer in the modern sense.
Cyclotronguy
New cabinets for Altec 416aHide this!Advertise here!
ALTEC A-7 cabinets built like ****!! bear Multi-Way 63 16th June 2007 02:23 AM
Altec 414z or 416a barossi Swap Meet 3 4th November 2006 02:48 AM
Altec 416A + JBL 077 santosa Multi-Way 1 21st July 2005 01:38 AM
Altec 606 Cabinets w/601 Duplex Drivers Benkev Swap Meet 3 22nd May 2005 06:09 AM
Copyright ©1999-2017 diyAudio
