Build or not to build - 0-500 budget
Old 4th January 2012, 11:23 PM   #11
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
$20 in china.
from $96 here
flesh flash flush
Old 4th January 2012, 11:27 PM   #12
ScottG is offline ScottG  United States
Originally Posted by Flaesh View Post
$20 in china.
from $96 here
Couldn't even find a supplier in the States..
perspective is everything
Old 4th January 2012, 11:36 PM   #13
Flaesh's Avatar
don't know shipping cost from China to US.
very few Chinese vendors sell for 2 drivers.
m.b. "clones" of b&c, rcf etc. is prohibited in US?
flesh flash flush
Old 4th January 2012, 11:49 PM   #14
"clones" aren't, but if it violates patent law then it's possible for a restraining order to compel the importer to deny it entry in the US.
Chances are though that it doesn't violate any patent (..compression drivers have been around for a long time, and a patent holder needs to have some new process or design that is being copied), and that even if it did - the patent holder must both be aware of the violation and seek the restraining order (or some form of recompense).
Old 5th January 2012, 12:01 AM   #15
Flaesh's Avatar
for sasav; cheap and documented : Drift Recipe
personally i definetly preferring normal comp. driver in cd horn crossed about 1k or lower..
flesh flash flush
Old 5th January 2012, 03:47 PM   #16
Inductor is offline Inductor  Portugal
Inductor's Avatar
The Eminence Legend B-102 is one of the best woofers in town. Congrat.
I know this from my previous tested simulations I show here.
EMINENCE LEGEND BP102, VB = 96.7 L, FB = 25.3 Hz, le 0 dB correspond 91.9 dB2.83Vm.
F3=36 Hz, F6=26 Hz, F12=19 Hz
Old 5th January 2012, 05:46 PM   #17
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Unfortunately xmax = 3mm only
Old 6th January 2012, 02:43 AM   #18
Inductor's Avatar
No, that's for the B102.
Bicone EMINENCE LEGEND B102 Die-Cast Aluminum - Mid-Range.
http://www.eminence.com/pdf/Legend_B102.pdf
EMINENCE LEGEND BP102 has Xmax = 6.2 mm. Pressed Steel - Woofer.
http://www.eminence.com/pdf/Legend_BP102.pdf
edit: Just to say that the driver in the project is not a woofer but a bi-cone mid-driver. I was referring to the woofer above.
Old 6th January 2012, 12:18 PM   #19
R.I.P.
Hi, consider https://sites.google.com/site/undefinition/tarkus : , rgds, sreten.
Old 6th January 2012, 03:27 PM   #20
malibujeff is offline malibujeff  United States
malibujeff's Avatar
Originally Posted by sasav View Post
head_unit,Flaesh,ScottG,
Even though I am capable of designing my own speakers, I don't have time for this right now, so can you suggest any good DIY design given my requirements?
Alex
Build! If you have $500 check out the GR Research N3. They also have some other less expensive kits that are not on their website listed here.
Build or not to build - 0-500 budgetHide this!Advertise here!
First build - have CNC, modest budget momerath Full Range 22 18th May 2012 02:30 AM
$1000 budget...what to build or clone? Frosteh Multi-Way 5 22nd November 2011 04:16 PM
Fast build - DubStep certified on a budget! Blindsite Multi-Way 2 8th May 2011 03:33 PM
Good ole budget build sub punkrokr1701 Subwoofers 9 3rd September 2008 08:56 AM
First time build help needed budget oriented sbrunkow Multi-Way 1 24th October 2006 06:23 PM
Copyright ©1999-2017 diyAudio
