Old 3rd January 2012, 07:42 PM   #1
Puffin is offline Puffin  United Kingdom
Default Griffin Speakers
I got these recently for a very good price and am very impressed with them. There is no information on the net about them (well very very little). I understand that they have the bass units used in the LS35A (Kef SP1003) and a Coles tweeter.
Anyone have any info?
Old 4th January 2012, 05:43 AM   #2
frugal-phile(tm)
planet10's Avatar
Griffin "27" Omega 3 Loudspeakers - Opinions?
Help with ID'ing Griffin Loudspeakers
http://www.hifiloudspeakers.info/spe...130064248166cf
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th January 2012, 10:49 AM   #3
Dave. Thanks for the links, I have in fact seen those, but they are not about the model I have. I believe that mine might be the "Phoenix" model. I would like to know what their specs are. They are pretty hard to drive and need a very meaty amp with lots of current. If they get it they sound superb.
Rob.
Old 11th March 2012, 08:25 AM   #4
deaks53 is offline deaks53  United Kingdom
Hi, they are a pair of later model Griffin type 15 speakers.
I had a pair myself and they are prettY good.
Old 11th March 2012, 10:18 AM   #5
No question that the tweeter in the photo is the Coles 3000. In Dave's reference (hifiloudspeakers) one of the posts correctly identifies it. According to Colin Royle (?) Coles bought the tooling for the HF1300 from Celestion and then marketed it. They did alter the faceplate (for easier mounting from the outside I guess). It sounds like the earlier version of your speakers might have had the ITT/STC/ Coles 4001. Higher frequency response i.e. over 20k but not used much below 6k. If they then moved to the HF1300/Coles3000 then that was probably a good move. It can work from around 2.5k but only up to about 14/15k Hz. So as you get older you will not notice the difference ha ha!! Cheers, Jonathan
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Come join me in my shop for a Griffin build naturallmystic Markaudio 64 9th August 2011 06:41 PM
Help with ID'ing Griffin Loudspeakers Thumpersteve Multi-Way 4 19th February 2011 08:16 AM
New Line Array Project - Jim Griffin others? Magnetar Multi-Way 35 10th November 2007 12:56 PM
bass extenzion for jim griffin minimonitor pamaz Multi-Way 8 22nd November 2005 01:25 PM
Jim Griffin pamaz Multi-Way 1 15th February 2005 05:40 AM
Page generated in 0.08212 seconds (72.82% PHP - 27.18% MySQL) with 10 queries
