Old 2nd January 2012, 11:36 AM   #1
Default 15W8530K00 or P13WH-00-08?
I recently built a pair of little monitor 2-way speaker using the mid/woofer
Vifa P13WH-00-08 and Scanspeak D2905-950000 tweeter in a 5 litre LS3/5A enclosure which I ported.
I like the sound but feel the bass is lacking even when compared to a pair of LS3/5a speakers.
I was looking at the Scan-Speak 15W8530K01 as a possible replacement as it has a lower FS of 30hz compared with the Vifa's 60hz and is coated paper instead of poly cone.
I would use this driver in a sealed enclosure as it has a low enough EBP.
Plotting in WINISD shows a vast improvement in bass roll-off.
How else do these two drivers compare? Is there are difference in sound between paper and poly?
The vifa’s cost £60 each, the Scan-Speak cost £150, are the scan-speak drivers over twice as good?
Old 12th March 2012, 04:08 PM   #2
Are you talking about the K00 or K01?
I have the K00 in the ZD5 designed by Zaph. It is a magnificent driver and way more bass than the Vifa which I also have in a speaker.
Any technology sufficiently advanced is indistinguishable from magic
Old 12th March 2012, 08:26 PM   #3
Inductor's Avatar
It's my opinion you can not compare a Mid (Vifa P13WH-00-08/F3=85 Hz, F6=65 Hz, F12=47 Hz) with a Woofer (Scan-Speak 15W8530K01/F3=40 Hz, F6=30 Hz, F12=22 Hz).
Unless you define your objectives.
The material of the cone is very much a choice of personal taste.
The Art of Speaker Design, Part II
Cone Materials Discussion
Old 12th March 2012, 08:45 PM   #4
Draki is offline Draki  Macedonia
I had a system with the Vifa (7L BR). It is a very nice sounding driver, as you already know.
Now have one with the 15W (Troels 15W/98000). The SS is in a different league however - probably the best bass (and the rest) that can be had from a 5" driver. Impressive. The cost reflects that. Probably the last 5" you will buy.
Old 12th March 2012, 09:20 PM   #5
I meant the 15W8530K01, being the better suited in a sealed enclosure.
I thought the Vifa was a mid/woofer but after hearing it I am also of the thought that it is better suited as a Mid.
But my original intention was to design a compact 2-way with out the need for extra woofers.
I have since taken apart the small 2-way speaker I built with the Vifa P13 and SS-D2905 and was toying with the idea of making a narrow baffle 3-way floor stander with a Seas L22RNXP side mounted woofer.
Old 12th March 2012, 09:39 PM   #6
Well, all I can say is the K00 is also suited to a sealed enclosure. It produces amazing bass for its size and the midrange is really great.
Any a Vifa P13WH-00-08 pair for sale? maartentje Multi-Way 12 25th March 2011 03:21 PM
4x new Vifa (Peerless) P13WH-00-08 h_a Swap Meet 1 30th November 2010 09:24 AM
Vifa P13WH-00-08 steph_tsf Multi-Way 0 21st May 2010 05:09 PM
Vifa XT25 and 2 x P13WH-00-08 project fury Multi-Way 8 25th May 2008 12:38 PM
Bookshelf with Vifa P13WH-00-08.... barackuda Multi-Way 7 23rd October 2006 09:13 PM
Page generated in 0.08522 seconds (77.02% PHP - 22.98% MySQL) with 11 queries
