4-8 Ohms - What does that mean
Old 31st December 2011, 12:06 PM   #1
JammyBStard is offline JammyBStard  United Kingdom
JammyBStard's Avatar
Default 4-8 Ohms - What does that mean
Quick Question:
If my Eltax Monitor III speakers State 4-8 Ohms on the back what impedance are they?
Old 31st December 2011, 12:58 PM   #2
GDO is offline GDO
GDO's Avatar
It means: Don't worry about my impedance. It is ok enough for whatever amp you might be using.
Old 31st December 2011, 01:24 PM   #3
So it means it's at least 8-Ohms then?
They've been sat on a shelf doing nothing for years; I've just pared them with a new TA2021B based T-Amp and I was wondering how they should stack up in theory. They sound supprisingly good actually.
The specs and internet myth of the TA2021B suggest it would be working at it's best into 4 Ohm and/or a hig-efficiency pair of speakers. The 89dB Monitor III are really doing the job for near-field.
Old 31st December 2011, 01:26 PM   #4
DrDyna is offline DrDyna  United States
DrDyna's Avatar
It means that the impedance varies with frequency as it does in most speakers. You should make sure that whatever amplifier you use is stable at 4 ohms.
Old 31st December 2011, 01:49 PM   #5
GDO is offline GDO
GDO's Avatar
For nearfield home use, i have never found impedance/power/sensitivity being a problem for any amp and any speaker.
Old 31st December 2011, 01:52 PM   #6
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
If you were to look at their impedance over the audio band you would be surprised. 2 Ohms to over 2K Ohms is not uncommon.
This, in part, is why Class D amps need to be matched to the speakers, whereas Class A is much more forgiving.
Old 31st December 2011, 01:56 PM   #7
system7 is offline system7  United Kingdom
system7's Avatar
I'd say that's a 4 ohm loudspeaker! LOL
Eltax Monitor III Bookshelf Loudspeakers | Hi-Fi
Nothing like seeing the actual impedance curve!
Old 31st December 2011, 02:16 PM   #8
Keriwena is offline Keriwena  United States
I'm going to guess it means 4 ohms when bridged, 8 ohms each when bi-wired.
Old 31st December 2011, 02:21 PM   #9
The impedance of the speaker doesnt change in Bridged or Parallel or Series modes.
The important thing is what is being presesnted to the amplifier.
The speaker manufacturer here is saying that these speakers will suit amps that require any load between 4 and 8 Ohms.
Old 31st December 2011, 04:15 PM   #10
Charles Darwin is offline Charles Darwin  United Kingdom
No idea what 4-8 Ohm means with these.
The other speakers I know which state '4-8 Ohm' were the large 215DMT & FSM Tannoys but with these the user could choose to run the extra 15" in parallel with the 15" DC or as a 3 way so it did make sense.
4-8 Ohms - What does that meanHide this!Advertise here!
4 ohms/ 8 ohms speaker epilot Chip Amps 4 13th September 2011 06:47 PM
8 ohms woofer plus 4 ohms tweeter? stf92 Multi-Way 9 27th August 2011 07:07 AM
15 ohms (12 on ohmmeter) with 24 ohms resistor in parallel to bring to 8 ohms McIntosh Man Multi-Way 29 11th June 2010 05:36 PM
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 03:29 PM
Speakers: 8 ohms vs. 16 ohms KT Multi-Way 2 14th April 2006 05:06 PM
Copyright ©1999-2017 diyAudio
