Old 31st December 2011, 04:15 AM   #1
angeloitacare's Avatar
Default Slotloaded Tapped horn
maibe the experts here could comment, if a design like this would work well.
Angelo
Old 31st December 2011, 05:27 AM   #2
Kahooli is offline Kahooli  Abu Dhabi
looks a bit like the decware projects.
Why not model it in hresp or aca
Originally Posted by sreten View Post
Quality done right always surpasses impressive looking mediocrity.
Old 31st December 2011, 10:38 AM   #3
rvrazvan's Avatar
I think you should try it!
Old 31st December 2011, 11:23 AM   #4
SunRa is offline SunRa  Romania
It does resembles a bit with this: DECWARE's Wicked-One Horn Subwoofer
Yeah,, you should model it..
Old 31st December 2011, 11:24 AM   #5
CLS is offline CLS  Taiwan
That's more or less like a small area horn mouth (with an abrupt flare).
In general, a smaller mouth give you lower cutoff, also a lower SPL.
By the proportion of the diagram, it'd be a midbass horn, not a sub. Also, tapped horns have severe resonant peaks in their higher range, which should be filtered-out, thus narrow usable bandwidth.
In the POV of the whole system, a narrow range midbass unit might not be a good idea. A plain straight midbass front horn with simliar cutoff, wider range, better directivity, smoother response... etc. won't be terribly larger than this.
You have several big round wooden tractric horns, don't you?
Old 31st December 2011, 11:59 AM   #6
The design has similiaries with the decware wicked one , but the idea is to sum
the advantages of a tapped horn, with the advantages of a slot loaded sub, and use it up to max. 150hz.
If the horn is too small for the intended frequency range, i might modify it. Maibe someone can help with
better suited dimensions.
Old 31st December 2011, 12:09 PM   #7
tinitus is offline tinitus  Europe
looks too short/small to function like a low frequency TH
Old 31st December 2011, 04:20 PM   #8
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Have a look at the Cubo Designs Hosted on Freespeakerplans.
Plans
The cubo has been built sucessfully as a dual speaker, simlar to what you propose.
Have a look at this quick sketch based on the Cubo sub to show you where your proposed design differs in the horn path proportions.
The panel between the speakers could probably be shortened, or removed.
Old 31st December 2011, 04:54 PM   #9
is a TH not born like a natural slot loaded design ?
Old 31st December 2011, 05:31 PM   #10
Plans
interesting. i would like to understand what distance one woofer would need to have to the other , to get a Heil-style loading effect. I guess the closer each woofer to the other, the better ?
Tapped Horn Feeding A Unity Horn Patrick Bateman Multi-Way 20 4th September 2010 01:27 PM
Can a Tapped Horn have a negative taper within the horn path? BP1Fanatic Subwoofers 6 13th February 2010 06:04 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Help with a tapped horn. mike james 533 Subwoofers 32 11th November 2009 02:34 AM
Page generated in 0.10750 seconds (82.02% PHP - 17.98% MySQL) with 12 queries
