Old 30th December 2011, 10:09 PM   #1
Default Crossover impedances
Hi there, I have purchased a Dayton crossover (2000Hz) which is designed for an 8Ohm tweeter. I didn't realise the tweeter I purchased is only 4 ohms. What are the implications of hooking these up? I currently have it running and it sounds fine.
Does it change the crossover point? I'm assuming the fix is to wire a 4 ohm resister before the tweeter?
Old 30th December 2011, 10:20 PM   #2
AllenB is offline AllenB  Australia
Depending on the crossover itself, it is likely to run the tweeter a little quiet near the crossover point, but otherwise it should behave similarly to an 8 ohm tweeter.
Old 30th December 2011, 10:35 PM   #3
Thanks for the reply Allen. It's a second order Linkwitz-Riley arrangement if that helps. Would you suggest running a resistor in series with the tweeter to bring it to 8Ohms?
Also, I've heard that if you use a 4ohm woofer on a crossover designed for 8 ohm woofer this affects the crossover frequency? Is this true?
Old 31st December 2011, 04:20 AM   #4
The effect of a second order type of crossover will be the same way above and below the crossover point, with just a change in level near the crossover point when the impedance is not as designed for.
A first order filter will cause the rolloff to happen at a different frequency, an actual shift. In the case of a pair of 4 ohm drivers with a generic 8 ohm style crossover, the responses will cut off away from the crossover point encouraging a hole in the response.
You asked about using a resistor, if you do it will make the tweeter more quiet. If this is needed then go ahead. It will also alter the response a little. If you don't need your tweeter reduced in level, then I wouldn't do this.
If you do notice a problem with a lack of lower treble, you could play with increasing the tweeter capacitance by clipping another capacitor in parallel with the one you have. This will partially compensate for the problem, but a lot depends on a lot of things.
Old 1st January 2012, 06:12 AM   #5
Thanks for the help Allen. I am pretty happy with the current result so feel no need to alter it. Hard to know exactly what is going on without proper measurements, but when I do a frequency sweep it sounds natural to my ears.
More impedances for Hammond 125E revintage Tubes / Valves 1 25th August 2009 02:40 PM
Matching Impedances dscrobe Tubes / Valves 3 26th September 2007 06:49 AM
Dual Speaker Impedances tom daghdha Subwoofers 22 24th July 2006 11:24 PM
line input impedances? Dominique Parts 5 5th August 2004 11:19 AM
Speaker impedances Vivek Everything Else 11 30th July 2001 08:07 PM
Page generated in 0.08236 seconds (69.46% PHP - 30.54% MySQL) with 10 queries
