Enough bracing? - Page 6 - diyAudio
Old 7th May 2006, 07:51 PM   #51
So, speaker´s pressure can squeeze a box?
Old 8th May 2006, 06:58 PM   #52
rho is offline rho  Belgium
Well, not realy squeeze. A speaker makes the panels vibrate. Since the Sd of such a panel is bigger then the Sd of the speaker the amplitude of the vibration doesn't need to be very big to produce enough sound to influence the timbre of the speaker. In most cases coloration by resonances of the box do not sound realy nice.
That's why you need to brace the box. This way the panels don't vibrate as much and you will have less coloration of the sound.
Bracing an enclosure preiter Subwoofers 5 17th July 2006 11:54 AM
Does A Box Like This Need Bracing? sdclc126 Subwoofers 10 12th May 2006 02:31 AM
how much bracing is enough gwgjr31 Subwoofers 1 5th May 2006 07:57 AM
do I need bracing for a 15L BR? RockysDad Full Range 12 11th August 2005 08:18 PM
enough bracing?? Chris8sirhC Multi-Way 3 31st January 2004 09:16 PM
Copyright ©1999-2017 diyAudio
