Old 29th December 2011, 08:18 PM   #1
lduarte1973's Avatar
Question Can i mix pro and home drivers ?
Can i mix pro and home drivers ? someting like this :
10NMB420 - High Output MB Neodymium Driver
99db
FaitalPRO - Professional Loudspeakers Made in Italy
96db
Bohlender-Graebener NEO3 PDR - RumoH - Caps, coils and speakers
93db
Old 29th December 2011, 08:33 PM   #2
4642a is offline 4642a  United States
sure, but the final result's quality may depend on how you deploy them....
Are your passive crossover design skills up to par?
or are you planning on using an active crossover?
Old 29th December 2011, 08:40 PM   #3
active crossover minidsp
Old 29th December 2011, 08:52 PM   #4
GDO is offline GDO  Spain
I am not sure that the 10' is a proper woofer. From the same manufacturer, i like better this one:
12NW530 - Extended LF Neodymium Driver
Old 29th December 2011, 09:07 PM   #5
i can go for that one too , but i have active 12 " subs for low end 30-80hz
Why is a pro woofer bad for home use? Rob41 PA Systems 80 24th February 2012 01:33 AM
F/S Art Pro Audio Micro Mix rubicon Swap Meet 0 27th November 2010 04:37 PM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 09:11 PM
FET+Bipolar follower biasing (To mix, or not to mix?) Wavebourn Pass Labs 6 27th September 2006 12:22 AM
Pro Audio Equipment In the Home CARTRulz Subwoofers 59 25th June 2006 05:09 PM
Page generated in 0.07707 seconds (72.49% PHP - 27.51% MySQL) with 10 queries
