#2 |
visaton did(wih grille
) Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories http://www.lautsprechershop.de/index...i/fiesta25.htm
flesh flash flush Last edited by Flaesh; 29th December 2011 at 07:34 PM. |
#3 |
I know that design
. It's a good sign but i need some more concret information, regarding sound quality. And the stock horn is not what i am planning to use bdw.
#4 |
Why would you want to use that in the first place ? What's the goal ? Efficiency ?
I don't believe in audio believings. |
#5 |
I think he's interested in it because it's going lower, to 200-250Hz or so.
ASRock AtomIon 330 -->V-Link-->SRC/DEQ/DCX2496-->3-way horn + multi-subs |
#6 |
I want to have a single source for most of the F range. And what can be better at this than a compression driver.
How bad is to cross over at 6500hz? At the right moment a better driver will replace them..one that goes to 10000hz at least. |
#7 |
Do you have a horn already and you're just looking for a driver?
I'm asking because you might want to consider a small cone with a horn as well. |
#8 |
I used Monacor KU-516 with good results (Universe 3-way).
#9 |
First hand experience is ideal!
I would like some subjective opinions also, if that is possible. Is is better that an cone in horn? Do they have any particular sonic defect? What's the best thing about them? Thank you! |
#10 |
It's like having affordable coax driver (BMS, BC) without its phase fidelity. Such a large horn I would recommend use with 8"-12" midwoofer, 2 or 3 octaves above 80Hz with midrange-tweeter driver in smaller horn like here:
http://horns.pl/galeria/Zoltan_2.jpg (supravox mid + radian tweeter) plus distributed subs (eg. Rythmik Audio?). For me sound is relaxing and constant regardless of volume. Subjective opinions -> StudioSound |
| fanon pro-120 pa. amplifier | newfie audio | PA Systems | 5 | 10th December 2011 02:18 PM |
| FS: Pyle Pro PPA15 PA Drivers (2) | theAnonymous1 | Swap Meet | 6 | 6th April 2009 01:37 PM |
| Indian PA pro here? | mhtplsh | PA Systems | 0 | 6th December 2008 02:49 PM |
| PA subs using Omega Pro 18's | soulfinger | Subwoofers | 4 | 28th July 2007 02:03 AM |
| Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? | thadman | Multi-Way | 7 | 11th November 2006 09:11 PM |
| Page generated in 0.10208 seconds (79.74% PHP - 20.26% MySQL) with 11 queries |
