Old 27th December 2011, 02:00 PM   #1
ARIYAHOOR's Avatar
Default Best material to paint glossy black piano?
Hi there dudes
A friend of mine wants me to build him a huge horn-loaded 3-ways speaker... he want the finish "Glossy Black Piano" ... I've painted black piano before on plywood but he want something exactly like pianos ... I just want your opinion about the material? what is the best material to paint in Glossy black? (bare MDF, Plywood, Chipboard with veneer, etc...)
like this:
I'll do:
1- use cellulose undercoat
2- wet sanding with Makita and then with some handy power
3- spray Black paint
4- wet sandpaper the black in different grades (1000 > 1600 > 2000)
5- spray semi Polyester
6- sandpaper and polish it again
7-after a month or so I'll wax it
shed some light if I'm wrong
Old 27th December 2011, 04:26 PM   #2
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
Core material of your choice and HDF shell (3mm thick). Below picture shows cross section of a budget speaker made by professional carpenter. Veneer-HDF-MDF(green, water resistant)-HDF.
Group buy list: http://www.diysoundgroup.com/
Visit us at http://www.horns.pl/
Old 27th December 2011, 05:28 PM   #3
lakeside's Avatar
A fine tight grained wood veneer like poplar, birch or maple. Core material of your
choice.
Old 27th December 2011, 07:28 PM   #4
bear's Avatar
Do a search there was recently a long thread on this finish...
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 27th December 2011, 07:32 PM   #5
ARIYAHOOR's Avatar
_-_-bear
yep but pictures don't show up
Old 27th December 2011, 07:44 PM   #6
bear's Avatar
I see that...
But the techniques are explained.
And, I thought that there was one more current too... dunno.
_-_-bear
_-_-bear
Old 28th December 2011, 01:37 PM   #7
dirkwright's Avatar
I'd use MDF for the base material. I think your technique is just fine and the results look good.
Old 28th December 2011, 05:01 PM   #8
oldmanaudio's Avatar
The key is many coats
Old 28th December 2011, 05:17 PM   #9
Plastic laminate works well as a top, too.
Old 28th December 2011, 10:45 PM   #10
pski is offline pski  United States
Originally Posted by ARIYAHOOR View Post
Hi there dudes
like this:
I'll do:
4- is also with a mech sander? If so, fast or slow?
6- same question except polish with what?
Thanks for your time
P
I know about letting the device do the work.
piano black or other high gloss finishes on MDF mondogenerator Construction Tips 13 20th February 2010 01:55 AM
Looking For Black Glossy Formica hongrn Everything Else 2 31st October 2006 06:24 PM
Applying piano black finish help Toast_Master Subwoofers 15 28th May 2006 06:48 AM
Anyone have any suggestions on Piano Black paint job? corryn00 Multi-Way 15 26th February 2005 02:41 AM
Page generated in 0.10097 seconds (78.79% PHP - 21.21% MySQL) with 11 queries
