Old 27th December 2011, 09:54 AM   #1
Default 3-way design with Jamo R909 mid/high; R907 bass
Hello everyone
I wish to build a pair of loudspeakers like this:
http://www.audiofil.no/images/respon...KV900_1314.jpg
I allready have the the drivers
2* http://www.scan-speak.dk/datasheet/pdf/d2905-970000.pdf
2* E0037-08S W15CH001
2* Jamo R907 woofers, i have the measurements for it. Crossover will be active - DCX2496 or similar.
Can i get some help with the design and CAD modelling ?
Old 27th December 2011, 11:07 AM   #2
AllenB is offline AllenB  Australia
Hi muskel. These have the potential to be an attractive piece of furniture. How are you going with it so far?
Old 27th December 2011, 12:45 PM   #3
Im in the process of planning right now. I have the drivers but need some input on how to further my design.
Old 27th December 2011, 01:25 PM   #4
You can start by working out some enclosure sizes for the woofer and mid, and putting them in boxes. I assume the mid should go in a closed box and the woofer seems to be in a vented one. The external dimensions are on the site you linked to. Try not to incorporate bumps or steps across your baffle, e.g. flush mount your drivers (particularly tweeters), and round the cabinet edges where possible.
Do you have plans to measure them once you have them in boxes?
Old 1st January 2012, 10:18 AM   #5
This is how far i got in Bassbox Pro 6:
http://dl.dropbox.com/u/55237764/Jamo%20M15CH-JAM.bb6
I cant seem to figure out the box dimensions.
Should i perhaps port both the mid and woofer ?
Jamo R909 Passive Open Baffle Project josephpo Multi-Way 67 10th February 2011 03:30 AM
Jamo R909 woofer? cyclo Multi-Way 10 3rd July 2010 07:43 AM
bass,mid,high tone and balanse control laki101 Chip Amps 1 26th January 2010 11:41 AM
what drivers used in Jamo r909? Kickin Wing Multi-Way 13 4th November 2009 07:36 AM
Bass/mid/high, are you sure? Raka Multi-Way 4 28th September 2003 04:22 PM
Page generated in 0.07772 seconds (71.59% PHP - 28.41% MySQL) with 10 queries
