Old 26th December 2011, 07:03 PM   #1
Default Crossover help
What is a good calculator for crossovers? It's a two way setup but my tweeter is 3~db more efficient than my woofer, so will I need to incorperate some kind of BSC?
Old 26th December 2011, 10:45 PM   #2
Speakerholic
Cal Weldon's Avatar
A crossover calculator is only a starting point and will rarely give good results. Here's some reading for you:
Introduction to designing crossovers without measurement
If the tweeter is more sensitive than the woofer, you require an L-Pad.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 27th December 2011, 09:52 AM   #3
AllenB is offline AllenB  Australia
BSC is not related to a woofer or tweeter, it is applied to the overall system. It amounts to some bass boost below a particular frequency, and for many conventional two-way systems it happens below the crossover frequency and this is just a matter of coincidence.
So assume you have crossed a woofer and tweeter to have a flat overall response. As a result of the BSC chosen, the woofer will have its top end reduced a little further. At the same time, the tweeter needs to be brought down to that same level.
Old 28th December 2011, 04:42 AM   #4
strawberry's Avatar
What is a BSC? Try 2 ohm, then 3 ohm.
Old 28th December 2011, 02:34 PM   #5
Speaking strictly as a newb, for me it helps to take a look at the ideal scenario, then work backwards based on how your situation differs.
Simplistically, it would be better if your woofer were more efficient than your tweeter, and that you choose a crossover point which happens to be right at the center frequency of the baffle step. Then you gracefully "lose" the woofer's extra efficiency because it's now compensating for the baffle step loss. No padding down of the tweeter required.
This of course requires that your crossover point and your baffle step frequency -can- be the same, that the woofer is indeed more efficient, that the tweeter can be crossed that low (unlikely unless your baffle is really skinny or your tweeter is more like a widebander).
If your tweeter wants to be crossed much higher than the baffle step -3dB point, then your woofer would need a BSC separate from the crossover (or alternatively, just prevent the baffle step loss with flush-to-the-wall positioning like an infinite baffle, or add a second woofer acting as a 0.5 driver, or make the cab compensate by providing gain in other ways, e.g. reflex loading, horn loading, wider baffle, etc.)
Old 28th December 2011, 03:01 PM   #6
Another way -- not practical necessarily, but just to illustrate what's at work.
Make your cab an undersized sealed box, with a pronounced bump in the response (e.g., a sealed box with a really high Q at least 1.0 but probably higher -- that's really high but it's just to show a point).
Now, is that bump of the right frequency and magnitude to compensate for baffle step loss? Most likely no, so just keep adjusting the dimensions of the box (keeping the same volume) until the "bump" of the undersized box meets up with the baffle step loss. Presto.
I'm not suggesting this will work in your case, it's just another tool in the toolbox, one particular strategy. Putting a big bump via an undersized box has other sonic consequences but everything's a compromise (apparently!)
Old 28th December 2011, 08:23 PM   #7
L pad calculator - attenuation dB damping impedance decibel loudspeaker speaker voltage divider - sengpielaudio Sengpiel Berlin
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
2 way crossover HELP!! jmechie1 Multi-Way 8 16th April 2011 08:16 AM
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
3-way crossover help insomniac2295 Multi-Way 1 20th November 2007 05:13 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.09727 seconds (76.64% PHP - 23.36% MySQL) with 10 queries
