Old 26th December 2011, 01:26 PM   #1
lduarte1973's Avatar
Question Is this a good cabinet for a 8" (alone) woofer ?
Dayton Audio TW-0.75MA 0.75 ft³ 2-Way Cabinet Maple 302-736
Old 26th December 2011, 01:37 PM   #2
bear's Avatar
No way to know.
You need to have the T/S parameters of the driver first, then drop that information into a simulator to see the resulting curve. That will tell you if the volume of the box is large enough for a given driver, and what freq response at the lowest frequencies you might expect. If you have too much volume, it is possible to reduce the volume inside. But you can not make it larger.
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 26th December 2011, 01:41 PM   #3
Visaton GF200
Nominal power handling 120 Watt
Peak power handling 180 Watt
Nominal impedance 8 Ohm
Frequency response (-10 dB) fc - 2000 Hz
Mean sound pressure level 88 dB (1 W/1 m)
Maximum cone displacement 20 mm
Resonance frequency fs 29 Hz
Magnetic induction 1,3 Tesla
Magnetic flux 930 µ Weber
Height of front pole-plate 6 mm
Voice coil diameter 38 mm
Height of winding 20 mm
Cutout diameter 190 mm
Net weight 2,5 kg
D.C. resistance Rdc 6,0 Ohm
Mechanical Q factor Qms 3,69
Electrical Q factor Qes 0,35
Total Q factor Qts 0,32
Equivalent volume Vas 73
Effective piston area Sd 214 cm2
Dynamically moved mass Mms 25 g
Force factor Bxl 9,2 T m
Inductance of the voice coil L 1,3 mH
Old 26th December 2011, 01:55 PM   #4
jerome69's Avatar
Yes, 21 liters for a closed box or an aperiodic box, f3~60Hz. I like a lot this config
Old 26th December 2011, 02:25 PM   #5
Thanks Jerome
Old 26th December 2011, 03:14 PM   #6
oldmanaudio's Avatar
50 Liters will give you a Qtc .707 which is max flat and a f3 of 48.5hz. This is with heavy fill in the box.
Old 26th December 2011, 03:39 PM   #7
Yes, Box is suitable. You can use a Bass Reflex for lower F3 (50Hz).
If you want some mid bass punch, tune box for Fb=55Hz. Damping is still good at System Q=0.67
AmpsLab.com
Old 26th December 2011, 04:14 PM   #8
Thanks guys this will be a closed box , also closed box for mid/tweeter and 1 sub for channel.
Old 26th December 2011, 05:26 PM   #9
Inductor's Avatar
Duarte,
Good luck with your new project. Is it a 2+1? Are you using 1 (?) of the Visatons as a sub?
GF 200 2 x 4 OHM
Old 26th December 2011, 08:07 PM   #10
Inductor makes a good point. This is a dual voice coil driver. Both coils in series makes it 8 ohms and EBP is 91 and Qts of 0.32 A vented box is a better choice.
25 liter box tuned to 37 hz with f3 53hz. In parallel makes it a 2 ohm load. Thats a hard load to drive. It pushes the box volume up to 35 liters tuned to 33hz and a f3 of 42hz. With only 1 coil used it makes it a 4 ohm load EBP of 45 Qts .65 which is better suited for closed box. Which pushes the box up to 50 liters. Are you sure about your t/s numbers?
12" PA woofer in vented 3.5 ft3 cabinet = good idea? dbrose Full Range 37 20th February 2012 03:48 PM
15" mid-woofer - 80 Hz to 1 KHz - for a sealed cabinet audiothings Multi-Way 6 7th February 2011 10:46 PM
Is the woofer on the back of the cabinet a good solution ? angeloitacare Multi-Way 5 16th November 2009 05:00 AM
my new cabinet for two 8" woofer denbo123 Multi-Way 8 14th May 2009 01:52 AM
Random 12" woofer in 100 liter cabinet Klimon Subwoofers 4 20th December 2006 03:16 PM
Page generated in 0.11469 seconds (80.70% PHP - 19.30% MySQL) with 11 queries
