Old 30th December 2011, 11:55 PM   #21
pski is offline pski  United States
Originally Posted by mdocod View Post
Hello John,
I just reviewed the thread and realized I have no reference for what the intended application here is. If I missed it I am sorry but I honestly have no clue if we are talking about a car interior, or a theatre, or a highly portable open space PA style system.
Eric
Giant woofers ring a bell?
Old 31st December 2011, 11:14 AM   #22
Hello John,
Eric
Hi Eric
it will be part of a rediculously large 2ch setup that will also be part of a HT.I will make the subs active crossed at 50hz.
john
thanks John
Old 31st December 2011, 01:08 PM   #23
Inductor's Avatar
EBP for closed box is lower than 60.
Old 31st December 2011, 01:13 PM   #24
not sure what you mean here?
thanks John
Old 31st December 2011, 07:49 PM   #25
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
Hi John,
4x IST 15.2.2 @3200W in 3ft^3 sealed per driver, (6ft^3 per side) w/50hz low pass active filter (yellow plot). Box size tuned to cross Pe and Xmax at ~20hz.
vs
2x IST 15.2.2 @1600W in ~8.5ft^3 BR boxes (1 box per driver), [5ft^3 chamber + ~3.5ft^3 port volume per box] w/50hz low pass active filter (green plot) This design is not excursion limited at full power until ~17hz.
vs
2x IST 15.2.2 @1600W in 11ft^3 6th order bandpass boxes (1 per driver), [5ft^3 rear chamber, 1.5ft^3 front chamber, ~4.5ft^3 worth of vent space per box] (purple plot) This design is actually not excursion limited at full power until 16hz.
Honestly, all of these possible systems are probably going to be more than loud enough. I just can't help but point out, the advantages of modern enclosure design. I've modeled up the above BR and BP box sizes with enough port size allocated to keep port noise to expectedly inaudible levels at full power. Half the drivers, half the power, better bottom end extension.
The last attached screen-shot compares the same reflex and bandpass boxes configurations from above, the sealed box sizes have been increased to 5ft^3 per driver (10ft^3 per side), input power has been lined up to match the vented box input power. (1600W total).
Eric
Old 1st January 2012, 03:46 PM   #26
Inductor's Avatar
That's how you find a driver's good for closed or BR.
Look at what Eric said @#12 here IS THIS TRUE?
True, I would say that bad drivers in BR (with a peak) are some very good drivers in closed box. And very nice drivers for car are very good round drivers (supposing he is referring to the round frequency response curve) for home, like JBL's as one example.
Is it really true!? humlan57 Full Range 10 11th January 2010 10:47 PM
Is it true? rick57 Digital Source 4 31st October 2006 08:50 AM
is this true???? kathodyne Tubes / Valves 16 29th January 2006 10:26 AM
True....true!!! mikeks Everything Else 4 18th June 2004 02:51 AM
Is this true? josefr Digital Source 3 9th April 2003 09:28 PM
Copyright ©1999-2013 diyAudio
