Old 25th December 2011, 10:52 AM   #1
Default Crossover Parts - INDIA
Hi, I'm keen to build a passive crossover for my 3-Way Hi-Fi System.
I've attached the pic in which i got the values of the Caps and Inductors of the Crossover.
I got the values from 3-Way Crossover Designer / Calculator
I live in Mumbai and i want to know where I can get these parts in the schematic.
I can also order online via credit card but i don't know retailers!
Help is appreciated!!
Thanks and Regards
Mark
Old 25th December 2011, 11:07 AM   #2
Those are nonstandard values (17.93uF ??) and you will not get them anywhere.
You should probably start by reading this: Preferred number - Wikipedia, the free encyclopedia
Then you can head over to Lamington Road where all manner of caps and coil can be had for the asking.
p.s. Some people find the all-caps INDIA in the subject line offensive. I've seen someone complain in the past.
Old 25th December 2011, 11:37 AM   #3
Inductor's Avatar
yajnaS,
I found your info on the e_number interesting.
Mark,
You can order parts for experiments from Parts Express. Keep posted.
Parts-Express.com Is Your Speaker Building Supplies Store: Raw Speaker Drivers, Speaker Kits, Plate Amplifiers, Cabinets & Coverings, Crossover Components & Assembled Crossovers, Speaker Repair, Design Software
Old 25th December 2011, 11:42 AM   #4
Inductor's Avatar
Originally Posted by yajnaS View Post
...p.s. Some people find the all-caps INDIA in the subject line offensive. I've seen someone complain in the past.
Do you mean you are? Sorry, you are complaining with no reason.
Old 25th December 2011, 02:21 PM   #5
I know that it isnt a standard value.
But I don't know where I will get heavy duty inductors in Lamington. Visha Electronics has small resistor sized inductors.
And w.r.t caps, what types should i use??
Old 26th December 2011, 11:16 AM   #7
When it comes to capacitors with odd values it is better to round it off to the nearest value..You may find some odd values in polyester caps which are more expensive and i have managed to get some of them here in Chennai.
as far as inductors is concerned it is the same story here..they have tiny resistor sized inductors which are unsuitable in a crossover because of very bad DCR values..however you can use some inductor winding applications on the net to determine the inductor winding specs and have it custom made by your local winder ,that has worked fine for me
Old 2nd January 2012, 07:07 AM   #8
Thanks for the inductor idea....I had actually thought about it! Will metal film capacitors work for a crossover?
Old 7th January 2012, 06:33 AM   #9
Change in plan!
Using Active Crossover....
Thank you for all your replies
Parts in Mumbai (India) Roushon Parts 271 25th May 2012 02:06 PM
Parts availability in India ashok Parts 1 8th June 2011 05:49 PM
[INDIA] Any DIYer made a Gainclone in India. willing to help? smarcher Chip Amps 62 2nd April 2009 05:05 AM
DIY Audio parts sourcing for Live Sound Reinforcement in India peterpan73 Parts 0 19th February 2004 11:28 AM
Page generated in 0.11080 seconds (79.08% PHP - 20.92% MySQL) with 11 queries
