Do the BL and Moving Mass seem to good to be true? Any other comments appreciated.
Driver is $15 2" square, Chinese made Balanced Mode Radiator, sealed full-range driver. An earlier version is for sale now with slightly less good specs than this. Thanks! And Merry Christmas everyone!
Jimbo "Television is the poor man's whiskey." Russel Baker Last edited by ro9397; 24th December 2011 at 05:11 AM. |
#2 |
I've seen legitimate specs on 8" diameter drivers with only ~20g moving mass. Assuming things scale down as expected, a 2" square driver should easily be able to get under 2g moving mass very easily. I don't see anything that pops out to me as being unusual about the specs listed. I don't like the fact that they have not bothered with a true Xmax rating, but have instead, posted an Xlim rating. I suspect that the actual Xmax of the driver is probably around 1mm.
| 15 inch woofers: which have low moving mass? | elac310 | Multi-Way | 107 | 24th April 2012 11:11 PM |
| Want To Buy 2SK146-BL 2SJ73-BL 2SK147-GR1 2SJ72-GR1 | megasat16 | Swap Meet | 15 | 16th September 2010 01:37 AM |
| Magnet mounting dipole drivers w/high moving mass | matevana | Subwoofers | 12 | 10th July 2010 12:44 PM |
| Mass Confusion Over LM3886 Bridge/Parallel Modes and National's Specs.? | MartyM | Chip Amps | 9 | 1st November 2006 04:13 PM |
| Audio Technica AT-F5/OCC moving coil Specs | BigBen | Analogue Source | 3 | 14th December 2005 01:23 PM |
| Page generated in 0.06711 seconds (68.41% PHP - 31.59% MySQL) with 10 queries |
