I am designing a small 2-way dipole speaker for use on a desk.
I plan on mounting an 8" inch driver (Seas L22RNXP) on an open baffle measuring 330mm/400mm and a 3" wide band driver (Fostex FE83En) in a baffless configuration. I have simulated this in "The Edge" measuring off axis at 15degrees. The first dipole peak for the 8" woofer ends at around 1500hz which is where the first peak starts for the 3" wide band driver. I could set crossover here but am under the impresion this is a bit high to run an aluminum cone driver of this size? So I am going to set the crossover in the middle of the woofers first dipole peak at 700hz and notch both dipole peaks and low shelf the wide band driver which is 5db down at the x-over point. I am using a MiniDSP which makes this fairly easy. The HF starts to roll off around 7K and I will have to low shelf the woofer quite a bit as well. Bellow is a screenshot of the plot in "The Edge". Am I along the right line with this idea? ![]() Uploaded with ImageShack.us |
#2 | |
www.dipolplus.de |
#3 |
I think you would be better off by putting that 8" in small closed box and make an open baffle on top with little fulrange
than optimize crossover according to the fr response with holm impulse this way you may end up with compact good looking speaker with decent sound in comparison to the ugly monster with no bass and peaky response just my opinion Last edited by adason; 21st December 2011 at 06:02 PM. |
#4 |
That makes sense, I have ARTA installed an a microphone ready to measure.
I have read your document on Baffles, very interseting and informative. Am I on the right track with this then? Last edited by rich31td; 21st December 2011 at 05:54 PM. |
#5 |
The dipole peaks are less relevant when you listen nearfield
I have something similar and love it!
http://gainphile.blogspot.com |
#6 |
Have now decided not to use them nearfield but instead as floorstanders, a bit like Gainphiles speakers.
I have ordered a Tangband W2-800SL 2" driver which I will use baffle-less and the Seas L22RNX/P is mounted on 22mm pine board 290mm/875mm, I have allready cut them to size and used a roundover bit on the front and back edges. Here is the edge plot. ![]()
#7 | |
Rudolf
www.dipolplus.de Last edited by Rudolf; 16th January 2012 at 10:46 PM. |
#8 |
Ah, okay, in that case I shall make a small baffle, round or square and no larger than twice the cone diameter. That also means it will require less eq'ing to achive a lower x-over.
#9 |
so...where is the result? pics?
#10 |
havn't got any further, it is snowing outside so will have to wait for it to warm up a bit. Need to use the router to flush mount the seas driver and that is it.
Will post pics when done. |
| Does open baffle suffer from baffle step? | 454Casull | Multi-Way | 15 | 19th May 2012 03:12 PM |
| Upwards aligned open baffle? ( pop box meets open baffle ) | OllBoll | Full Range | 3 | 28th March 2011 01:00 AM |
| Murphy baffle radios [ open baffle ] | keithpeter | Full Range | 10 | 11th September 2007 07:59 PM |
| what effect does baffle have on open-baffle system? | kappa546 | Multi-Way | 6 | 24th January 2006 10:21 PM |
| Australians- what solid timbers for baffle? (open baffle loudspeaker) | tktran | Multi-Way | 13 | 29th November 2004 11:09 PM |
| Page generated in 0.11021 seconds (77.91% PHP - 22.09% MySQL) with 10 queries |
