Old 21st December 2011, 09:30 AM   #1
Default newbie Wanna start a unity Horn project
I am a newbie for horn, and i want to build a unity horn, my concept is simple
i want to make a unity horn with 2 compression drivers cover anything from 700hz (or lower) to let;s say 14K hz and a super tweeter upto 30Khz
this unity horn may be crossed at 700hz range..or can be lower
i read a lot about unity horns at here, 2 ways units horn, with a compression HF with 2 to 4 mid range cones..
is it possible ?
Old 21st December 2011, 06:14 PM   #2
MaVo is offline MaVo  Germany
not possible. driver to driver spacing must be less than one quarter of the wavelength of the crossover point. but i heard BMS has coaxial compression drivers, which do what you want.
Old 21st December 2011, 06:25 PM   #3
let's me check the BMS..., many thx
thx for pointing out this quick note..
by the way, any horn maker still make those dual throat?
Old 21st December 2011, 07:53 PM   #4
SunRa is offline SunRa  Romania
If you want fidelity I suggest you forget dual slot horns, they are against everything we learned about waveguide and horn contours in the past decade or so..
The coaxials pointed out by MaVo are a good starting point though. There are some successful projects out there in the wild, the most known one being the one from BD-Design.
Old 22nd December 2011, 05:04 AM   #5
but i can see..some example of unity, or synergy horn, those separation of drivers..deos not seem to be 1.4 of the crossover frequency, as that idea seem so logical for high SPL and point source, and keeping the structure smaller..too
also wonder..how;s the tonal color of BMS and B&C ?
Old 22nd December 2011, 09:14 AM   #6
wondering.., what is the bad side of having 2 identical MF drivers feed into one horn ?
thx..for any advice..
apart from BMS coaxial compression unit..., any other maker also make something similar?
Old 22nd December 2011, 03:25 PM   #7
Well there would be the same effects as feeding four drivers. The SPL halfs and probably the phase response of the crossover needs to be adjusted. Having just two drivers also means higher distortions (because less SPL).
Maybe there are some advantages also, but I can't figure out what those would be, except price..
As for simillarities between feeding two compression drivers into a horn, vs the synergy concept, well there is much to talk. It all depends on the crossover point and whether the entry hole of the CD's remain acoustically invisible to the other at the selected crossover point. And that basically means bellow 1Khz if I understand this correctly.
Tom Danley actually does this with his JH 90
but then he crosses those CD's (coaxials from BMS) fairly low, around 500-600Hz I guess.
Old 22nd December 2011, 06:06 PM   #8
soething like that... any comment for it?
Old 22nd December 2011, 07:33 PM   #9
el`Ol is offline el`Ol  Germany
What speaks against a ribbon and two compression drivers? I see no alignment problems in such a setup.
Driver suggestion for a proof of concept speaker:
http://www.parts-express.com/pe/show...number=264-204
http://www.hifisound.de/oxid/oxid.ph...8ffb0.05235853
Old 22nd December 2011, 08:09 PM   #10
That type of throat plumbing causes severe peaks and nulls, you probably won't find a plot published for that dual driver horn.
Multiple HF drivers plumbed in a manifold to a small throat actually can get loud enough to cause air nonlinearity, "throat distortion".
Tapped Horn Feeding A Unity Horn Patrick Bateman Multi-Way 20 4th September 2010 01:27 PM
Another Unity Horn Patrick Bateman Multi-Way 324 16th December 2009 02:15 PM
Not Another Unity Horn Patrick Bateman Multi-Way 29 26th July 2009 04:17 AM
Unity Horn Project Progress Sheldon Multi-Way 16 8th February 2007 04:18 AM
Page generated in 0.10594 seconds (78.92% PHP - 21.08% MySQL) with 10 queries
